P1316 code after an overheat
Old Aug 31, 2018 | 06:22 PM
  #21
Toran's Avatar
Hello again,
Got everything taken apart and here is how she looks.
Valve stem on #8 broke.
The head gasket looks to be in good condition with no missing material, no sign of any coolant in the oil.
Attached Thumbnails P1316 code after an overheat-psx_20180831_190521.jpg   P1316 code after an overheat-psx_20180831_190746.jpg   P1316 code after an overheat-psx_20180831_190637.jpg   P1316 code after an overheat-20180831_174552%7E01%7E01.jpg   P1316 code after an overheat-20180831_174900%7E01.jpg
Old Aug 31, 2018 | 10:42 PM
  #22
OverRover's Avatar
Oh the HORROR!!!!!
IMHO, based on these pics it's time to source a decent set of heads.
Start with a PM to abran & paul grant they should have something decent, and at a good price.
The rest of the bits to replace are obvious.
I would just look at this as a complete topend rebuild and have at it.
But that's just me, your rig...your choice.
Embrace the suck, but don't try to do a quick fix. If one valve just took a $hit guess which one is next.
Good Luck!!!
Old Aug 31, 2018 | 10:54 PM
  #23
Toran's Avatar
Thanks OverRover.
Trying to source a ready to go pair of heads now rather than replace just one valve to be on the safe side
​​​​​​​Thanks
Old Sep 13, 2018 | 04:57 PM
  #24
Toran's Avatar
UPDATE
I got everything all cleaned up and was able to source a pair of clean and reconditioned cylinder heads. Got them installed along with all new gaskets, bolts, and a fuel filter and she fired right up.
This was my first head gasket job. I just took parts off and off and off till I got to the head. The only pain was getting the valley gasket holes to line up on the block. I simply stayed with in until it was done. Fired it up when all complete and it sounded much better. Had a small amount a smoke coming from the manifold, not sure if it was from oil or a possible leak farther down.
In the end I have to once again thank this site for all the helpful threads on this matter.
Thanks!
Old Sep 14, 2018 | 08:02 AM
  #25
OverRover's Avatar
It's very good to hear you stuck with it and sorted this mess out!
And maybe more importantly you didn't have to use PLAN B
Old Sep 14, 2018 | 08:06 AM
  #26
Toran's Avatar
Agreed!
I had to stay with it. Now that I got that under my belt I am more confident about future repairs.
​​​​​​​Thanks again!
mware18
May 23, 2018 10:43 AM
micahb
Feb 16, 2018 10:55 AM
03discoman
Feb 11, 2010 10:58 PM
IDAHODISCO
Nov 20, 2009 08:12 PM
jasons
Aug 17, 2009 11:50 PM
