So what did you do to your Disco today?
Old Jul 25, 2013 | 07:17 PM
  #1761
RobG4's Avatar
Lubricate Hinges & door locks
Change transfer case oil
Change both of the diffs fluid
Renew manual gearbox oil -2nd renew
Grease u joints & prop shafts
Grease swivel *****
Old Jul 25, 2013 | 07:22 PM
  #1762
Got any lube left for the hood latch cable?
Old Jul 25, 2013 | 07:32 PM
  #1763
Royal's Avatar
Discovered drippy leak was pin-hole in transmission cooler line. Best price was Parts Geek - on its way.
Old Jul 25, 2013 | 08:05 PM
  #1764
bob&tina's Avatar
We met a couple of the St. Louis guys at the Arkansas rally. We live at the far sw corner of the state so we play with the arkies more than the show me folks. and figured out how to do the avatar thing too.....wooohoooo
Old Jul 26, 2013 | 03:38 AM
  #1765
Hercu's Avatar
Originally Posted by CUpgt
Yours are correct. Ones that mount on the bottom are inverted cones. A large majority mount on the upper spring perch.
Gee.... Thanks!
My hart missed a few beats when I saw your pics.
(Clamping that heavy duty's and lifting the Disco almost threw the porch roof isn't easy)
Nice job on the panhard bar!
Old Jul 26, 2013 | 03:42 AM
  #1766
Hercu's Avatar
Not to be forgotten !!!!
If not done, the wife won't be able to open the hood in few months time.
Old Jul 26, 2013 | 05:56 AM
  #1767
RobG4's Avatar
Going to do it this morning!
Old Jul 26, 2013 | 12:00 PM
  #1768
FLA Rover's Avatar
Cussed it a lot, then cussed it some more. Went to do tune up and radiator flush and hood wont fully release...
Old Jul 26, 2013 | 03:59 PM
  #1769
CUpgt's Avatar
Mail man was like Santa Clause today! A lil Friday afternoon Rover ****!
Old Jul 27, 2013 | 12:12 PM
  #1770
scottmb23's Avatar
Default Spacer correction, fuel filter and safari cut.
Busy day with the Green Machine yesterday!
Removed the old fuel filter which I suspect has been causing some issues, replaced with the Atlantic British kit which was surprisingly easy, despite being a bit of a bugger getting the clamp bolt on. Not a terrible job though, fully advise it to beginners who might think its a bit much.
While I was at, I corrected some of the bolts on the rear Bulldog hubcentric spacer, for some reason some of the bolts had come loose which was a surprise so re-torqued everything which corrected my highway wobble, for now, need to get some loctite.
Also took a grinder to my back fenders and whipped off a few inches on each side, might need more but it least it will stop catching on my 265/75/16 Mudders when I back out my driveway, will likely be a different story on the trail.
For good measure I also fitted my hood-mount for the Firestik and CB, still need to feed it through the firewall, another time.
Finished up with a MAF/Throttle-body and Idle Control Valve clean, all in all, a good day and off to hit the trails with my 5 year old in tow...should be interesting.
