So what did you do to your Disco today?
Old Aug 5, 2013 | 11:50 AM
  #1801
Sam95disco's Avatar
Originally Posted by fishEH
Uhhhhh, what? 6 gallons at $76 is the equivalent of $3.16/quart. How is that high dollar??
Just feels like it when I buy it, its a head thing
Old Aug 5, 2013 | 11:55 AM
  #1802
Sam95disco's Avatar
Originally Posted by Hercu
Sympathy!!!
I had the same "thing", vibe after installing new shocks and springs.
Driving with that vibration cost me a new Transfer case and oil seal replacement on diff.
Few Kilo's further, another diff seal and Transfer seal.
Then I lowered the Disco by +/- 2.5" by cutting out the lift spacers.
Phased the front propshaft 45 deg "Out of Phase" , had it balanced and the vibration was gone!
NS: I would recommend to replace that Rotoflex coupler with U-Joints.
Did you get the vibe all the time?
I only get it when I go over 55 and hit the gas, once I let off the gas it stops.
I'll look into the u-joints after the coupler wears out.
I have no spacers just hd tf springs an shocks +2.
Old Aug 5, 2013 | 12:46 PM
  #1803
fishEH's Avatar
When's the last time you greased your Ujoints? Whta's the condition of them?
The D1 front propshaft kinda sucks straight from the factory. Even on a stock truck its borderline needing a DC shaft. LR was cheap and decided to install the single cardan out of phase to get it by. Notice how even the stock D2's come with a DC front shaft? So when you lift your D1 the front shaft gets even more wonky. Now, most people can lift their truck 2" and run the stock shaft A-OK. However, there are exceptions to this. Especially when running a HD lift on a truck with no additional weight(bumpers, winch, skidplates, rack, etc). You may just be one of those unlucky folks.
The simple test is to pull the front proopshaft, lock the cdl, and drive it. If the vibe is gone then the shaft is your problem. You can also thoroughly inspect and replace the ujoints when you pull the shaft.
Old Aug 5, 2013 | 01:00 PM
  #1804
Motorvated's Avatar
Looked at it and thought "I wish I knew how too fix you" :/
Old Aug 5, 2013 | 01:02 PM
  #1805
fishEH's Avatar
Hahaha, too funny!!
This is turning into a typical gay Dweb thread, LOL.
Old Aug 5, 2013 | 03:33 PM
  #1806
Sam95disco's Avatar
They look fine to me, I greased them yesterday. I never messed with the cdl before. Only moves from 4l to 4h.
Edit: Just checked it it won't move to locked, also shifter doesn't look like the one in this vid(4h to the right and down)
Damnit! All I hear is $$$$
@#$% I think I put the coupler on wrong! @#$%^&@#$%$%^^G EFHFBDFGBsdvdvsVDFF
Old Aug 6, 2013 | 05:44 AM
  #1807
Hercu's Avatar
I also had it only on acceleration on highway over 55-60 Mph (100-120 Kph)
On gravel road it wasn't that noticeable.
The vibe was still there even after lowering.
The 45 deg "out of phase" made 99% improvement and balancing 100%.
The coupler ?? with TF+2 springs and shocks it wont take you many miles to wear out. Sorry!
Old Aug 6, 2013 | 08:00 AM
  #1808
Sam95disco's Avatar
I saw the kit on atlantic for $200 US.
Going to check junk yards to see if any trucks I find have the shaft I need.
Old Aug 6, 2013 | 08:16 AM
  #1809
CUpgt's Avatar
I have one. Its painted yellow and needs a rebuild though.
Old Aug 6, 2013 | 09:09 PM
  #1810
honda50r's Avatar
