03 Disco Tranny Noises
Old Dec 29, 2007 | 06:10 PM
mattvaughnjr's Avatar
Default 03 Disco Tranny Noises
Its at 130k miles and making some strange noises. When I'm in the gas there is a chirping similar to a water pump going out, but this only when there is a load on the motor (not when in neutral). Then when the vehicle is coasting to a stop and down shifting there is a growling sound (that one is harder to describe). Has anyone come across this? I am just hoping that it is not the transmission. I've already redone both head gaskets and am not looking for anymore big "investments" in this vehicle for a while. Thanks a lot!
mv
Old Dec 29, 2007 | 06:14 PM
geotrash's Avatar
Default RE: 03 Disco Tranny Noises
Just a few thoughts. Have the front driveshaft u-joints been replaced? Is there any vibration associated with the noises while driving?
Dave
Old Dec 29, 2007 | 06:18 PM
My bet is on the front drive shaft, and if that is the problem I would suggest you not drive it at all till you can find someone to rebuild the drive line installing new u-joints with grease fittings.
Crawl under the truck with a flash light and see if the front drive shaft, where it hooks to the t/case, has grease fitting, if it doen't that is your problem. If it fails while driving a dealer will charge you around $7000 to replace thye tranny and broken shaft.
Old Dec 29, 2007 | 06:40 PM
There is a slight vibration that I have recently noticed. I stopped driving it out of fear of it worsening. I just checked for the grease fitting and could not see one. You are talking about a normal-looking grease fitting that could be greased with a gun right?
I am a DIY'er (famous last words) is this something I should attempt on my own?
Old Dec 29, 2007 | 06:53 PM
okdiscoguy's Avatar
Probably not. I would call a tranny shop and get a quote. Should be under $200. The problem is the centering ball in the double cardan joint by the transfer case. Let a pro handle it if you haven't done one yourself...well worth the$$.
Get it done soon. I wouldn't drive anywhere until it is fixed. If it breaks, it will slap the tranny out of the truck...
Old May 13, 2012 | 03:44 PM
RR NEWBY's Avatar
Cant you remove front ds and lock diff so you can still drive on rear for short time
Old May 13, 2012 | 03:54 PM
If you have CDL or can access the spud for it on transfer case on units not so equipped, yes.
moorebl
Dec 28, 2013 08:06 AM
Blatallic
Jan 17, 2007 06:33 PM
askewm
Dec 23, 2006 11:03 PM
Desertdualsport
Oct 26, 2006 01:12 AM
spiderfreak80
Mar 16, 2006 03:19 AM
