2000 disco 2 head gasket job
Old Sep 13, 2013 | 07:20 AM
  #31
You need that 72 inch flat screen to be able to check the RAVE......
Old Sep 13, 2013 | 07:25 AM
  #32
drowssap's Avatar
at least you had a game to watch all I had was the pats VS the giants
Old Sep 13, 2013 | 03:04 PM
  #33
a-rod's Avatar
Damn right
Old Sep 13, 2013 | 03:05 PM
  #34
a-rod's Avatar
Same thing I watched, crappy game but a good excuse to take a break
Old Sep 15, 2013 | 05:36 AM
  #35
a-rod's Avatar
es anyone know where I might get a used secondary air injection adapter? I really don't want to spend 90 dollars on one
Old Sep 15, 2013 | 07:10 AM
  #36
Paul Grant comes to mind, or another dismantler.
Old Sep 19, 2013 | 12:10 AM
  #37
a-rod's Avatar
So guys, I got problems. I got it all put back together., refilled the fluids, and ready to start up. At first start it didn't want to start. I turned it off and waited a second, tried to turn it over again and it started, but a very loud knocking from the passenger side rocker cover, then the engine died.............. I am unsure of the ground on the coil pack. I am not sure if it is grounded correctly or if there were 2 different grounds for the coil pack. Or if it is something completely different. I am going to pick up my computer from a friend tomorrow and see what codes it throws and will post them on here for you guys to see.
Any suggestions or comments or thoughts or your an idiot a-rod and this is what you did wrong would greatly be appreciated.
Old Sep 19, 2013 | 06:47 AM
  #38
drowssap's Avatar
"I" would pull that VC, it is quite easy to misalign a push rod, especial if you put them in after the intake gasket.
Old Sep 19, 2013 | 08:50 PM
  #39
a-rod's Avatar
Codes p302
Cyl 2 misfire
P1590
Old Sep 20, 2013 | 04:50 PM
  #40
jfall's Avatar
Push rod on Cylinder #2 was not seated correctly.
