2004 Disco 2 Engine Rebuild
Old Mar 20, 2020 | 04:47 PM
  #251
cvhyatt's Avatar
Default 3-20 Update
Looks like the spring clips fixed my P0441 error. Haven’t had an issue for over a month so I’m going to call that one solved.
The fix I did for the driver side door looks like it is holding up as well. https://landroverforums.com/forum/di...e3/#post722040
Lastly I got my oil analysis report back from Blackstone. Need to keep an eye on the chrome but other than that it looks good. Truck is running great and I am digging the $2 premium gas!!!
Oil analysis report after 5000 miles.
Old Apr 10, 2020 | 09:52 AM
  #252
cvhyatt's Avatar
Replacing front passenger side door actuator today. Wish me luck!
Old Apr 10, 2020 | 10:17 AM
  #253
The Deputy's Avatar
Good luck!...you'll need it. Those bast*ards are wedged in there tight. Hate working inside the doors on any vehicle but these actuators are the worst.
Brian.
Old Apr 10, 2020 | 01:40 PM
  #254
RoverSE7's Avatar
yeah i have 3 to do uggg. both driverside front and rear as well as the back gate.
Old Apr 10, 2020 | 02:42 PM
  #255
XRAD's Avatar
I have to do my driver rear as soon as parts arrive.......post some pics CVH!
Old Apr 10, 2020 | 06:27 PM
  #256
cvhyatt's Avatar
Default 4/10 Update
Replaced the drivers side lock actuator with a used part from Will Tillery $60 and it came a a few days. Whole job took about 2.5 hours and I was taking my time doing it.
Previous video from Mr. Foreman was immensely helpful. Followed along with the YouTube video on my chromebook while I worked on it and paused it as needed. Not sure I can add much to that but I have a few tips.
Good Luck!
This was a used part. I cleaned it up with some contact cleaner to get a lot of dirt and hunk out of it. Then lubed it up with wd-40 and silicone spray.
The stripped door - ready to be attacked!
One of the trickier parts is unlatch this mechanism but if you watch the video and have good lighting, it’s pretty straightforward.
The hardest part was putting the actuator back in. In the video Mr Foreman looks like he is putting it in through the bottom opening but I found the second opening was easier. Only issue was angling it around the window frame.
Old Apr 11, 2020 | 12:39 PM
  #257
cvhyatt's Avatar
Looks like my power steering box leak is getting worse. Whole underside is covered with power steering fluid. I don’t want to do a full rebuild and a new box is not on my budget right now. Can anyone help me identify which seal I can replace in order to fix this?
I think this area is the source of the leak.
Old Apr 11, 2020 | 02:59 PM
  #258
XRAD's Avatar
power steering pump or hose? not the steering box....
Old Apr 11, 2020 | 03:33 PM
  #259
cvhyatt's Avatar
xrad - you are right, that is the power steering pump. I originally thought I had a steering box leak. Now I think it is leaking down from the pump. I have dried both the pump and box and will check for leaks tomorrow.
Old Apr 11, 2020 | 03:59 PM
  #260
No Doubt's Avatar
New power steering pumps were cheap when I did mine. Less than $100. Lots of peace of mind from doing that because power steering fluid is so flammable that I don't like it to leak into the hot engine compartment.
