4.6 Crank, Rods, Cam, Harmonic Balancer Value
Crank - Id say $600-$800
Rods w/ piston get about $65-80/each depending on shape
Camshaft - I sell new for $100
Harmonic Balancer - Atlantic British asks $509, I sell new Genuine for $410
Hope these help your frame of reference
WNYErikDiscoII (05-05-2015)
You are going to need to pull it first and make sure there is no scoring on the bearing surfaces of the crank. There will be a big cost difference between just polishing the crank and turning it on a lathe. In addition, even thought there is no scoring, sometimes the crank needs to be turned because it has a slight bend or bow to it.
Rods need to be straight and almost always they have to be re-sized by a machinist.
To be able to really price them correctly, they should be inspected by a machine shop. If you just pull them out you should be prepared to ask the low end pricing as the buyer doesn't know what they are getting until it is all checked out.
mouse
05-18-2012 12:25 AM
