97 discovery II, burning oil
Old Oct 9, 2014 | 03:08 PM
Hallhomestead's Avatar
Default 97 discovery II, burning oil
Please forgive me if this question has already been asked, could not find one that matched my situation.
1997 Land Rover Discovery II
4.0 liter
87K miles
Bought my Rover 2 years ago and love it. The previous owner had just replaced the head gasket. It did smoke very little from tail pipe when I bought it. I have a cabin up in the Ozark Mountains. I noticed from the start, I would have to add 2 quarts of oil when I got up there, 2 hour drive, and 2 quarts when I returned home. Now it is smoking pretty good , still only adding 2 quarts oil on my trip to the cabin.
While trying to figure out my loss of oil, there is something I can't wrap my head around. When up on the mountain, I engage the differential and the smoking stops. The whole time riding up there , no smoke. When I leave and disengage , smoke again.
Also, when driving around in town it wants shift real hard. If I stay on the accelerator when shifting .... it's a normal shift. If I am at a complete stop and take off.... And for some reason if I let off accelerator before it does it's normal shift.. It's a real hard shift.... Almost like I manually slammed it in to low gear at too high rpms.
Thank you in advance for reading my thread .. Any ideas or advice would be appreciated .. I have stopped driving it until I can figure out what could be causing my issues. I really don't want to get rid of her any can't find anyone local that works on them.. They are almost scared when I mention the word Land Rover.
Mike
Old Oct 9, 2014 | 03:23 PM
ZGPhoto's Avatar
Ahh yes the earliest discovery 2 ever made, 1997?
You may be in the wrong forum
Head gasket failure or worse it sounds like
Old Oct 9, 2014 | 03:35 PM
abran's Avatar
piston rings
Old Oct 10, 2014 | 05:55 AM
drowssap's Avatar
I would suggest you check your PVC system to see if it is working, otherwise its time for a compression test.
I would not be surprise if the valve seals are all cracked and brittle by now.
tacker
Jul 10, 2010 09:36 PM
Macroni
Oct 3, 2008 03:17 PM
jhall2
May 3, 2007 12:48 PM
socalrover
May 25, 2006 12:22 PM
doeboy
Sep 10, 2005 08:07 PM
