Automatic Trans fluid in Axle Oil
75W is gear oil. Fine in the diff if that is all that is available, especially in cold weather. The multi-grade oils suggested above are better for all year driving conditions. Maybe take a sample and compare to ATF, 75W should be way thicker, and probably stinkier.
This guy has shown with his ungrateful attitude in several of his threads that he is a first-class a$$hat. Probably not to the level of being banned, but a good old-fashioned boycott of his requests for help may be in order.
I kind of miss good ol' David O'Hendo. Once you understood him he provided some entertainment value.
Yes. But the bottle says for use in automatic and manual transmissions - and my other bottle says gear oil. max gear sythnetic.
