bad battery causing ABS faults???
Old Jan 15, 2018 | 07:03 AM
rmcc's Avatar
Default bad battery causing ABS faults???
After researching on this site (thanks to all , by the way) I am wondering if my battery is the cause of the 3 amigos not clearing or resetting? I have noticed starter drag lately and chalked it up to being so cold. I have never had the 3 amigos stay like this. I am going to get a new battery today and see if that solves part or all of problem. Any thoughts???????????
Old Jan 15, 2018 | 08:43 AM
Fast951's Avatar
Doubtful it is the battery. Temperature changes causing Three Amigos usually points to a faulty ABS module. If you can afford it replace the electronic half of the unit. If money is tight perform the work-around fix.
Old Jan 15, 2018 | 09:37 AM
Best4x4's Avatar
You have an ABS hard fault stored. It will not just reset or go away on it’s own. Once you get that scantool that can read the faults report back with what it tells you. Option B & possibly some new sensors might be all you need. Also P1590 will never clear until the actual LR specific faults are cleared first.
Old Jan 16, 2018 | 02:13 PM
rmcc's Avatar
Follow up:
Had a friend look at it with his diagnostic, was R front wheel bearing. Ordered new hub, should be here Friday. Thanks to all!!
Old Jan 16, 2018 | 10:08 PM
OffroadFrance's Avatar
A duff battery or even a duff alternator will cause 3 Amigos and even the M&S faults. The SLABS, Trans ECU and even the engine ECU require the full voltage available to operate correctly.
Lr3edm
Jan 6, 2019 04:53 PM
Titus
Oct 19, 2015 11:40 AM
LandyMatt
Oct 14, 2015 10:22 PM
FlyingZebra34
Nov 19, 2013 03:07 PM
rebooTT
Jun 20, 2005 01:09 AM
