bcm bcu replacement.
Old Jan 14, 2016 | 09:15 PM
  #21
hokkabaz's Avatar
Well, the actuator was working when I bought the truck about a year ago, but few weeks later driver door, right rear door and the sunroof stopped working. I figure out that when i gently punch the sunroof switch, it works. So i guess it is just a lose connection. Right rear door is never used so i never even bothered to take a look at it. And now the drivers door is fully functional,well almost. Because of my redneck repair, now i wont be able to put the window down because the ziptie is on the way hahah
i still need a REAL solution for it, but i guess i should stop pushing because the system is so complicated
Attached Thumbnails bcm bcu replacement.-20160114_205724.jpg   bcm bcu replacement.-20160114_205721.jpg   bcm bcu replacement.-20160114_205717.jpg
Old May 5, 2018 | 10:48 AM
  #22
vonfrese's Avatar
6th Gear
My D2 is disabled I think tripped by the key lock tumbler being broken or just spinning around. Is is difficult to replace or repair?
Old May 6, 2018 | 08:22 AM
  #23
abran's Avatar
Old May 6, 2018 | 10:23 AM
  #24
Saturnine's Avatar
Top bit of kit right there.. Get one!
Old Dec 12, 2023 | 08:47 AM
  #25
Mo 3's Avatar
Originally Posted by roverpdx
the learn security code said "function terminated" when tried it but it may be I tried it once already??
changed eka to 1515... still wouldn't run.
then finally successfully synced the remote... still wouldn't run.
locked unlocked several times... still wouldn't run.
luckily i wrote down the original eka code.
put in the original eka code... runs like a champ.
Now I get to do it all over again with the second valeo bcu with compatible miles. Thanks Jafir for the hints.
where can I find original code?
Old Dec 12, 2023 | 02:40 PM
  #26
Harvlr's Avatar
In theory the LR dealer should be able to get it for you, but I wouldn’t count on it.
Old Dec 12, 2023 | 07:31 PM
  #27
mollusc's Avatar
A Nanocom can read (and change) the EKA code from the vehicle.
Old Dec 13, 2023 | 01:15 AM
  #28
JUKE179r's Avatar
A Foxwell, Lynx and Hawkeye can read/change the D2 EKA code also.
floundering
Jul 7, 2015 04:53 PM
justinthorpe
Feb 18, 2015 10:41 PM
Street Wolf
Sep 28, 2012 12:59 AM
ajh
Apr 6, 2012 10:47 AM
losbadgts
Dec 31, 2008 12:15 AM
