bcm bcu replacement.
Well, the actuator was working when I bought the truck about a year ago, but few weeks later driver door, right rear door and the sunroof stopped working. I figure out that when i gently punch the sunroof switch, it works. So i guess it is just a lose connection. Right rear door is never used so i never even bothered to take a look at it. And now the drivers door is fully functional,well almost. Because of my redneck repair, now i wont be able to put the window down because the ziptie is on the way hahah
i still need a REAL solution for it, but i guess i should stop pushing because the system is so complicated
the learn security code said "function terminated" when tried it but it may be I tried it once already??
changed eka to 1515... still wouldn't run.
then finally successfully synced the remote... still wouldn't run.
locked unlocked several times... still wouldn't run.
luckily i wrote down the original eka code.
put in the original eka code... runs like a champ.
Now I get to do it all over again with the second valeo bcu with compatible miles. Thanks Jafir for the hints.
where can I find original code?
