Cat heat shield
my center ball in the cardon isn't grease able. Only the two outer u joints. I've pulled the ds and will attempt to smear cv grease in/ on it. Any advice?
I had the front ds on my bench today so i had "great" access to the joints. I tried using my grease needle but the ball and socket, which bty are in great shape, just kept smearing/ screeting the cv grease off. I probably applied a film on but only after working some warmed 175w gear lube in first. Once the oil was in it acted as a transfer medium as i worked it while suspended vertically in a vice, applying cv grease in a little at a time. I must say I don't like the exposure of the ball/socket to the heat and elements. Next replacement will be with a greasable center.
PeteDub (09-09-2023)
EVN137
10-07-2009 09:22 AM
