Cat heat shield
Old Sep 9, 2023 | 10:15 AM
Killerkaw's Avatar
Default Cat heat shield
In performing maintenance on the ds of the d2, specifically the front ds,i got to wondering about making a heat shield for the passenger cat. The purpose is to protect the cv.
Has anybody done this with success?
Old Sep 9, 2023 | 12:00 PM
Best4x4's Avatar
Grease your front drive shaft with good grease say Lucas Red & Tacky at every oil change and you should be fine.
Old Sep 9, 2023 | 12:03 PM
Killerkaw's Avatar
my center ball in the cardon isn't grease able. Only the two outer u joints. I've pulled the ds and will attempt to smear cv grease in/ on it. Any advice?
Old Sep 9, 2023 | 04:00 PM
Alex_M's Avatar
I've heard of folks using a grease needle. Never tried it myself.
Old Sep 9, 2023 | 06:07 PM
Extinct's Avatar
Grease needle yes, heat shield yes. Search here and on Amazon. Universal shield available very cheaply.
Old Sep 9, 2023 | 06:36 PM
XRAD's Avatar
it's not the best insulator, embossed air gap aluminum, but better than nothing and only takes up a tiny bit of space. i used this:
amazon search:
Peastorm Exhaust Heat Shield Automotive Embossed Aluminum Heat Shield Muffler Exhaust Wrap, 15" x 39"
Old Sep 9, 2023 | 10:06 PM
Killerkaw's Avatar
I had the front ds on my bench today so i had "great" access to the joints. I tried using my grease needle but the ball and socket, which bty are in great shape, just kept smearing/ screeting the cv grease off. I probably applied a film on but only after working some warmed 175w gear lube in first. Once the oil was in it acted as a transfer medium as i worked it while suspended vertically in a vice, applying cv grease in a little at a time. I must say I don't like the exposure of the ball/socket to the heat and elements. Next replacement will be with a greasable center.
Old Sep 10, 2023 | 05:28 AM
Extinct's Avatar
A little bit of a pain but best to remove it every oil change and grease it on the bench.
cappedup
Jul 14, 2015 06:42 PM
coors
Feb 5, 2013 01:03 PM
EricTyrrell
Jul 23, 2012 10:10 AM
hilltoppersx
Oct 28, 2009 12:14 PM
EVN137
Oct 7, 2009 09:22 AM
