Changed Plugs, 02s, and CPS rough idle now and misfire cyl 1 for not
Old Jan 19, 2018 | 08:54 PM
  #31
Alex_M's Avatar
I think the ones I got were generic. Maybe not, but I got whatever was cheapest.
  #32
sickws6's Avatar
How long you been running them.
Old Jan 19, 2018 | 09:22 PM
  #33
OverRover's Avatar
100% STI Plug Wires, NGK Plugs, and Standard Motor Products (SMP) Coils UF545.
The last set of SMP coils I installed ran no issues for 2 years, sold the truck to a friend and he put another 1.5 plus years on them (he still owns the truck). What can I tell ya, the coils and the other parts listed above work well.
Rockauto sells the coil SET for about $43.00 but you can get them at any local auto parts store.
> More Information for STANDARD MOTOR PRODUCTS UF545
Old Jan 20, 2018 | 12:42 AM
  #34
shanechevelle's Avatar
Every vehicle I have always gets 8mm, a good 8mm.
There is a core to a spark plug wire. You can have a 8mm that doesn't make a difference and sometimes you can have a 7mm that feels better.
What does this mean?
What it means, the center, the core, could be made from cheap material, or it isn't really 8mm. A good 7mm can flow better than a weaker 8mm. The 8mm might look fatter due to more outer material, but the center could be the same as the 7mm, or be 8mm but cheap material, thus making more resistance.
I'm with a couple others...coil pack, wires.
Old Jan 25, 2018 | 06:47 PM
  #35
sickws6's Avatar
Changed coils and wires today. Not that bad of a job. Engine is running smooth. Problem is I broke the freaking brittle *** coolant hose to the throttle body. And broke the Nipple off reservoir trying to replace it. Going to yard tomorrow. They have 3 discos right next to work!
Old Jan 26, 2018 | 07:29 AM
  #36
Fast951's Avatar
Good news -- I suspected bad coils. The boneyard coolant pipes will probably be brittle and ready to break so get those new. I've seen good used reservoirs so you should be okay there. Now's a good time to replace the throttle body heater plate and gasket.
Old Jan 26, 2018 | 08:38 AM
  #37
number9's Avatar
You can replace the plastic pipes with 5/16" heater hose. It eliminates those short connector hoses & a couple of clamps.
Old Jan 26, 2018 | 08:42 AM
  #38
sickws6's Avatar
I'm gonna do that!
Old Feb 24, 2020 | 12:28 PM
  #39
Du Toit Mike's Avatar
Default Lr3 v6 petrol 2006 model crankshaft sensor
Good day my lr3 goes into limp mode ,took it to a macanic ,the computer say lamda sensor bank one ,lean bank one lean bank two lamda sensor low voltage crankshaft sensor fault
i did replace all lamda sensort and crank sensor after 3days still the engin light goes on nou again same story
abran
May 4, 2014 10:36 AM
kaldonia
Jun 1, 2012 05:24 PM
dh42891
Jul 26, 2010 12:37 AM
lipadj46
Apr 20, 2010 12:59 PM
cottonpatchweims
Aug 15, 2005 11:19 PM
