Discovery II - Rear Hub Replacement or o ring only
Old Sep 2, 2009 | 08:38 PM
jeffzx9r's Avatar
What fun is THAT????
Old Sep 2, 2009 | 08:40 PM
lipadj46's Avatar
Wink
It's $450 fun every time a bearing goes bad.
Old Sep 2, 2009 | 11:28 PM
mattyh007's Avatar
Should I be using any grease on the D2 when I replace the bearing?
also, if i get the rebuild version from roverlandparts, it does not come with the ABS sensor. Is this as easy as moving from the one that is there now?
thanks
matt
Old Sep 3, 2009 | 04:05 AM
lipadj46's Avatar
I bought one from roverland parts and if I were to do it again I would save some money and get a used one elsewhere. Yes they come with an ABS sensor and they are easy to replace anyways.
You can't replace the bearing. You need to replace the entire hub assembly and it does not need grease. Only replace if it is bad though. Just because it is leaking gear oil does not mean it is bad.
Old Sep 3, 2009 | 07:53 AM
If your brake fluid is low, you probably have a blown caliper seal. Pull your brakes apart and see, and while you are at it, order a new set of brake pads today cause you are going to need them.
Old Sep 17, 2009 | 02:07 PM
mattyh007's Avatar
Default change hub or o-ring
ok...after many weeks of delays i finally have this assembly apart
when i rotate the old hub, i dont hear anything unusual (no marubbing or grinding)
if the hub is bad, would it be very clear
it feels a bit grittier than the one i got from roverland, but then again mine has 150K on it.
so do i replace whole hub or just o-ring. i am happy to get a $200 credit with roverland for other stuff.
btw...i know the issue is hub or the o-ring as the purple grease was coming right out
thanks for your advice
-matt
Colorado David
Jul 21, 2014 03:19 PM
robgusto
Feb 4, 2014 05:35 PM
LADEROUTE
Dec 29, 2013 07:22 PM
KyShark
Dec 21, 2011 08:01 PM
mattyh007
Sep 17, 2009 10:27 PM
