Doing my head gasket and....
Old Jan 7, 2012 | 09:50 PM
jrm123180's Avatar
Default Doing my head gasket and....
Hello all!
So i'm finally getting around to doing my head gasket. Surprisingly the teardown went along pretty smoothly. I planned ahead and everyday for 4 days I soaked everything down with PB Blast....LOVE that stuff, even the exhaust manifold bolts came off with easy.
I'm a bit concerned with the color of the valves/cylinders on the drivers side. I have attached a pic, I"m figuring it's possible from overheating when my coolant ran low, but I"m not sure.
On the Passengers side, there seems to be a lot of carbon build up on both the heads and pistons. SHould I clean the tops of the pistons off with anything?
The TOP pic is the drivers side and the BOTTOM is the passengers side.
Thanks again,
Steve
Attached Thumbnails Doing my head gasket and....-drivers-side-head.jpg   Doing my head gasket and....-pass-side-head.jpg
Old Jan 7, 2012 | 10:05 PM
You'll be wanting to check for flatness (spec .002 inch, your printer paper is about .0038). Machine shop can mill them for you, and tank them for clean up. ABout $200 total.
Old Jan 7, 2012 | 10:06 PM
jrm123180's Avatar
I have a place, I'm going to drop them off Monday....
Old Jan 7, 2012 | 10:08 PM
see this post for similar issues and pix https://landroverforums.com/forum/di...t-blues-46337/
Old Jan 8, 2012 | 01:26 PM
jrm123180's Avatar
Thanks!!!! very much like mine
Disco Mike
Jun 21, 2012 09:32 AM
bradbenz
Nov 5, 2010 02:13 PM
DarylJ
Nov 4, 2010 05:02 PM
XxRoverAllOverxX
Oct 4, 2010 02:47 PM
Robwsup
Mar 11, 2010 10:28 PM
