End All answer to stupid oil questions.
Old Apr 1, 2013 | 09:12 PM
  #181
Bkreutz's Avatar
Originally Posted by Rock Sing
How do you feel about the Lucas oil stabilizer. I want to run the 5w 40 or 15 w 40 but already purchased a but load of 5w 30 si motor oil. I find the starting up in the morning is a bit ragged with the lite weight oil so the 15w 40 cj oil soulds great. Lucas oil seems to help. or should i go ahead and run the 15w40 cj and use the 5w 30 sh in my other car?
Depends on what your other car is. I wouldn't use it in a Rover unless I was in snow country in the winter.
Old Jun 5, 2013 | 04:04 PM
  #182
CPTLOU's Avatar
Compatibility
Please choose your vehicle year, make and model for specific results.
To confirm that this part fits your vehicle, please choose a vehicle from your My Vehicles list OR enter your vehicle's Year, Make and Model.
My Vehicles
1997 Land Rover Discovery
  • Select a vehicle
  • Saved Vehicles
  • Recently Viewed Vehicles
  • 1997 Land Rover Discovery
  • 1997 Land Rover Discovery XD
  • 2003 Land Rover Discovery
  • 1976 BMW 2002
  • Manage vehicles
Manage vehicles
YearMakeModelTrimEngine-Select-20132012201120102009200820072006200520042003200220 01200019991998199719961995199419931992199119901989 19881987198619851984198319821981198019791978197719 76197519741973197219711970196919681967196619651964 19631962196119601959195819571956195519541953195219 51195019491948194719461945194419431942194119401939 19381937193619351934193319321931193019291928192719 26192519241923192219211920191919181917191619151914 19131912191119101909190819071906190519041903190219 0119001899189818971896-Select--Select-All TrimsAll Engines
Please wait
We were unable to complete your request. Please try again later.
This part is not compatible with 1997 Land Rover Discovery.
Old Jun 5, 2013 | 04:07 PM
  #183
CPTLOU's Avatar
So,
What is the veredict?
Are these filters safe on A Disco.........?
The compatibility tables says it does not fit.
Old Jun 5, 2013 | 04:49 PM
  #184
Sorry but my PC won'rt show what you are looking at with that large post. Are you looking for an oil filter? From what source? Which web site?
This thread started with the Purolator 40316, which is a re-boxed MANN W950/4, which I run on my D1. There are other jumbo filters, from brands like Baldwin and Wix, the advantage is greater oil capacity. A filter should be priced where you are not tempted to run more than 5000 miles between oil changes. Many also use the Mobile 1 filter. There are all sorts of reports on types of bypass valves, etc. The Fram seem to be more cardboard and and ad dollars. But the main thing is a new filter every oil change, and don't make Rover wait. The 7500 - 15,000 mile changes are a product of the ad department. The diesel rated oils have more cleaning and Rotellla has lots of ZDDP which is good for flat tappet engines. It is not modern engine. It is a 1963 Buick Skylark engine with electronics added to satisfy the various regulatory agencies. Back in the 60's people changed oil every 1000 - 3000, and a truck was considered worn out at 50,000.
Old Jun 7, 2013 | 10:58 AM
  #185
RoverMasterTech's Avatar
Originally Posted by CPTLOU
So,
No they don't fit. I actually work for MANN. We had 1 million filters we couldn't sell, so we setup a deal with purolator to rebox them and sell them in the states to dumbasses who think they will fit in their cars. But due to low sales I was laid off and abandoned by MANN in New Jersey, left with only a shipping crate full of useless huge oil filters and a strap wrench. But with photoshop and a laptop I was able to go on many forums and get people to believe this filter fits on Landrovers and audis. Little do they know that the filter will cause their engine to explode with the force of 10 killotons of TNT if used for over 4999 miles (MUHAHAHAHA).
Vunce all mine vilters are zold I Ville retrn to zee Fazaland a national hero, Having decimated all zee capitalists ingeens!!!
Old Jun 8, 2013 | 01:30 PM
  #186
vwhammer's Avatar
Well I went to pick up some of the Rotella 15w40 and order one of the two different filters L40316 (High bypass pressure) or L40107 (low Bypass pressure)
I was going to go with the Low pressure filter.
However after the parts guy looked it up it appears that they are discontinuing that particular filter and they cannot order them anymore.
I did manage to find a couple online but they were north of $20
The High pressure filter is still available so that's the one I went with.
looks like that may answer the question as to which one to get unless you decide on another brand.
Old Jun 8, 2013 | 04:05 PM
  #187
dparham's Avatar
and So I.... I ordered 1 just now on amazon... it is the W950/4 for $12 each .... I also have been running T6 Rotella with a 3001 filter... one thing though... at hot idle ive noticed around 8-9 but fluctuates up around 10-12 which it used to always do intil last oil change... its always been around 10-12 when hot idle and 40+ around 2000rpm ( hot.. ) when cold its idling I think I remember around 30+ but Ill get more accurate data..... Im in south florida where it rarely gets cold at all so Im going to bump up to 15-40 Rotella T and see if my hot idle will increase... I dont like it low around 8-9... it also is a little erratic occasionally when idle but rock solid once driving.... and with this new MANN 950/4 and Rotella T well see what happens! hopefully not POW! lol
Old Jun 8, 2013 | 07:12 PM
  #188
antichrist's Avatar
Keep in mind that with a higher bypass pressure your engine can be oil starved for a longer period of time if conditions are less than ideal.
In fact, given the Rover V8 lubrication system specs, your engine could be oil starved even under near ideal conditions if the filter is dirty enough.
Old Jun 8, 2013 | 07:36 PM
  #189
dparham's Avatar
Ill keep an eye on it... I change oil every 3500 miles and when I first got it I changed it to rotella T6, ran it 600 miles and changed again just to get some of the gunk if their was any, out of it from prev owner... it was in ok condition but did have some issues mostly just time for maintenance however I didnt know previous owners oil change habits... I just know what I do... lol I may goto Rotella T though just because it never gets cold here and to my texas standards, it doesnt get hot here either in S Florida lol
Old Jun 8, 2013 | 08:13 PM
  #190
I thought the bypass valve did just that, bypass the filter media depending on pressure drop, blockage, etc. So a dirty filter won't stop oil flow, it just stops the filter process. The bypass valve also operates at WOT accelerations, racing, etc. I think a filter that is clogged AND has a stuck valve would starve the oil.
So with a Mobile1 filter run until clogged, or any other brand, continues to flow unfiltered oil. But with the price you paid for the Mobile 1 and the synthetic oil you keep driving for another 15,000 miles with no filter....
Good quality filter and oil, and change early and often like voting in Chicago. Rover says under certain arduous conditions oil may have to be changed daily. Sounds like fun to me!
Exactly how does a bypass valve work? - Bob Is The Oil Guy
Pix of arduous conditions and results of poor oil change habits combined with blocked PCV system.
Fuel for thought - does a high cleaning oil Like Rottela, in an older engine, remove so much sludge that the filter media becomes clogged early and the filter stays in bypass mode?
Attached Thumbnails End All answer to stupid oil questions.-bush-rover-nairobi.jpg   End All answer to stupid oil questions.-p1050979.jpg
