The fix
Old Feb 9, 2019 | 04:04 PM
  #31
NewToTheTwo's Avatar
Originally Posted by redwhitekat
Good info folks we are all here to help
what is a vacuum pump ??
The bracket under the hood that holds the cruise diaphragm, that has the cable attached that goes to the throttle body, also holds the vacuum pump.
The hoses everyone suggest to check go between those two parts.
Old Apr 21, 2020 | 06:04 PM
  #32
redwhitekat's Avatar
Don’t forget to post your issue and what fixed it. Helps out everyone
Old Apr 21, 2020 | 09:06 PM
  #33
greisinb's Avatar
P0440: Purge Valve Failure/Sticking. The previous owner decided it was easier to cut out the “check engine light” than to buy the $25 dollar Hyundai part and spend 10 minutes replacing it. So I spent $25 and 10 minutes to fix it followed by an hour to disassemble the gauge cluster, solder a five cent through hole LED back in place and reinstall.
Old Apr 22, 2020 | 12:26 AM
  #34
rhyslegge's Avatar
Default Low end knock at idle
Persistent knock hot or cold below 2000 rpm, changed the rod bearings, oil pump and timing kit. Knock has gone away 100%.
Rhys L
Old Apr 22, 2020 | 11:25 AM
  #35
Rhys L
nice work
what was the actual problem? Bearings ?
Old Apr 22, 2020 | 10:25 PM
  #36
Jason_B's Avatar
Problem: Engine overheated after about 2 min.
Solution: Longblock, oil pump, water pump from Turner Engineering.
Old Apr 23, 2020 | 04:38 PM
  #37
rhyslegge's Avatar
nice work
Oh yeah, bearings were well past it. Timing chain was ridiculously slack, but the oil pump looked great. Had the new one already, so I threw that in too with lots of Permatex Ultraslick red and petrolatum. But the bearings- yes, they were knocking for sure.
No babbit, looks like copper. Saw copper- like flakes in last oil change.
You could feel the lip where the white soft metal remained.
Every bearing looked like these did. Wish I had the time to do mains while I was in there.
Rhys L.
dmenchaca1966
Oct 18, 2018 10:14 AM
Richard Gallant
Jun 24, 2018 08:53 PM
Externet
Mar 17, 2015 12:46 PM
04SSHD
Apr 24, 2012 12:49 PM
smllikphysh
Oct 27, 2008 06:44 PM
