Ignition won't turn
Old Dec 17, 2010 | 08:53 AM
matt3502's Avatar
Default Ignition won't turn
My 04 D2 did soemthing new this AM. Got in, went to turn the ignition key and it would not move a millimeter. Jiggled it for over 5 minutes before it turned. Damn near missed my train Any thoughts or suggestions on how to prevent this in the future?
Old Dec 17, 2010 | 09:15 AM
Auto Parts Guy's Avatar
Try moving the steering wheel a little bit next time it happens while you turn the key.
Old Dec 17, 2010 | 09:23 AM
willrok13's Avatar
A shot of graphite lube would probably help as well (in all locks...)
Old Dec 19, 2010 | 04:08 PM
Rovin4life's Avatar
but if it doesn't turn then its seized up and needs to be replaced. What we do at the dealership is to replacee the cylinder from a locksmith. we take it out and send it to them and they install a new one and away we go. The trick to take it out is to remove the lower cover with a philips screwdriver and then take a long flat screwdriver and a hammer and bang the shear bolts out. you have to tap them to loosen then up. They originally had a head on them but they shear off at a specific torque for security feature. once they are loose you can disconnect the entire ignition switch at the fuse box and other two connectors and take it to a locksmith to get reset.
Old Dec 19, 2010 | 04:28 PM
texmbr's Avatar
This had me in a fit just after buying my wife's 01 Disco. Move the steering wheel to the left a little while turning the key.
Old Dec 21, 2010 | 12:36 AM
HelenaRover's Avatar
I let my wife drive my LR to the grocery store the first weekend I owned it... she proceeded to rip the remote off the key trying to remove it from the steering column. I came to the rescue with pliers and a tube of crazy glue, needing only to turn the steering wheel to release the key.
Discos will find a way to trick you... like putting buttons in weird places, placing bolts in locations no human being can reach without 3ft of extensions attached and two universal joints, ungreasable u-joints paired with a greasable u-joint on the same drive shaft, lots of drains that clog easily and flood the interior, and yes... not letting go of your key.
RobsRover
Apr 13, 2019 03:33 AM
tgvas
Dec 28, 2011 09:13 PM
Lwulf
Jan 31, 2011 02:55 PM
Disco Canuck
Dec 14, 2009 09:03 PM
babylucy
Dec 4, 2008 10:37 PM
