Learning about a 2003...
Old Sep 26, 2025 | 08:52 PM
Externet's Avatar
Question Learning about a 2003...
Hi all.
The coolant reservoir cap is different (flatter/smaller) than my 2000. What is the improvement ?
Had it idling for 1 hour+ with blower fan disconnected to test if went too hot... Every ~2 seconds a double chirp heard by the top of engine. Is it something related to the SAI ?
Engine is quiet but something is roaring near the coolant reservoir. Is that a blower for the SAI am not familiar with ?
The fuel door has no actuator button. How does it open ?
How to remove the headlights lens to clean / polish ? I prefer the older glass type. Is there glass under the foggy plastic ?
The driver's door lock top tab is missing. Will investigate if its rod is also missing inside. By the way, what is it for ? Never used it for anything in my 2000
Ash/coin trays do not work
Thanks.
Old Sep 26, 2025 | 09:28 PM
whowa004's Avatar
no glass under the foggy plastic but it does polish up fairly easily. other than that I don't know much about the SAI equipped or 03-04 models
Old Sep 26, 2025 | 11:26 PM
arains44's Avatar
The fuel door actuator is on the cluster behind the wheel on 03/04 trucks and on the dash under the radio on 99-02 I believe.
Old Oct 2, 2025 | 01:49 PM
Externet's Avatar
Question
Stumbled to this post from a decade+ ago :
What page/where to find that on RAVE ? What are the differences for SAI and not ?
Old Oct 2, 2025 | 10:40 PM
nashvegas's Avatar
The radiator for SAI just has a little port to screw in a temperature sending unit (which the SAI uses to turn on / off when the car is cold)
Non SAI radiators don’t have that port.
Old Oct 5, 2025 | 09:03 AM
Best4x4's Avatar
99.9% of all D2 Radiators sold today = are SAI compatible meaning it comes with a plug in that sensor hole. If you have SAI = you remove the plug & if you don't = you keep the plug in place.
Old Oct 11, 2025 | 01:41 PM
Externet's Avatar
Question
Good day all.
Scratching my head... Need your knowledge.
The 2000 cap goes deep and has 2 orings.
2000; overflow has a slit; radiator top hose has a 2mm hole in the wall of the reservoir where the cap fits..
Above, 2000; overflow has a slit for it in the innerwall; radiator top hose has a 2mm hole in the innerwall of the reservoir where the cap fits..
The 2003 It is not like this, does not have the long center with 2 orings
1999-2004 Discovery II Radiator Coolant Overflow Tank Cap PCD000070-D2 - Picture 1 of 2
This below is what I have in the 2003 :
The 2003 cap is shallow, there is no slit for the overflow in the innerwall of the reservoir.
Cannot tell if the '2003' cap is broken missing a portion or belongs to another year or two types of caps/reservoirs. Exteriors are identical.
Is there reasons other than blown head gasket for the coolant not pressurizing ? (2003 - No drips, no oil lever rise) Have an extra 2000 coolant reservoir cap for diagnosing but is different than the 2003. Interchangeable ?
Someone installed a wrong year cap ? What is the last cap image for ?
Help !
Old Oct 11, 2025 | 02:23 PM
Best4x4's Avatar
That short cap = doesn't look OEM. All D2 & P38's had the long center reservoir cap.
Old Oct 13, 2025 | 03:13 PM
evil_goat's Avatar
Agreed. My 2004 has the same cap with the two o rings.
Externet
Sep 24, 2025 10:13 PM
Massrover
Dec 1, 2021 08:53 PM
Codyt
Sep 14, 2017 12:10 AM
ivanwood
Sep 2, 2017 09:57 AM
sanrover
Feb 26, 2013 10:38 PM
