load noise when engage reverse
Old Jul 1, 2005 | 01:33 AM
wbudna2's Avatar
Default load noise when engage reverse
hello all
new comer here
i have a 97 disco 101,000 miles
when i put my disco in reverse it makes a load clunking noise from the front right of the truck. and it also does it when i am driving at 60 mph and let go of the gas pedal i here it go back and forth clucking in and out. what could that be could someone shed some light on this or has any other experience this before and what was the solution to fix it. it sounds really bad like something might brake in there.
thanks for your time
will
Old Jul 1, 2005 | 11:21 AM
GadgetRick's Avatar
Default RE: load noise when engage reverse
I seem to remember reading a post on a board somewhere indicating it might be a transfer case or something like that. If I remember correctly, if it's coming from the front (like yours) you should have it checked out. If it's from the rear it's supposedly common and won't cause a problem, it's just annoying.
Sorry I can't be more detailed.
The Rickster
crsone
Apr 6, 2013 12:02 PM
geoffreyworthington
Mar 26, 2012 11:41 AM
b18cx
Sep 24, 2008 09:51 PM
tobob1
Oct 3, 2006 11:37 AM
db1047
Apr 27, 2006 08:10 PM
