Missing rubber piece. Where?
Old Nov 18, 2016 | 08:51 AM
LR03NJ's Avatar
Default Missing rubber piece. Where?
Hi guys, where can i get this part? I went to check if i have oil leaking but i found this. there should be a rubber cap. I just dont know where to find the part to get. I think its under the transmission. Not quite sure, I got disoriented that night this picture was taken. Thanks
Old Nov 18, 2016 | 09:15 AM
Red5's Avatar
This is what you want.
Oil Pan Grommet (Rear) (Genuine Part # ERR7229 ) - Land Rover gaskets and seals from Atlantic British
There is one on the starter side as well.
Old Nov 18, 2016 | 09:33 AM
LR03NJ's Avatar
Originally Posted by Red5
Thanks, ordered the part. $15.90 inc ship
Old Nov 18, 2016 | 09:59 AM
abran's Avatar
Lucky8 is on your coast and way cheaper than AB, plus they Iove to beat AB's pricing.
Call and talk to Erik.
Old Nov 18, 2016 | 11:53 AM
LR03NJ's Avatar
Another question please: Is the part inside need to be oiled? Seems dry inside, Thanks
Old Nov 18, 2016 | 12:04 PM
robert.juric's Avatar
Yea I took my oil pan off doing this HG job and I'm wondering what the purpose of that grommet is. Mine is way to loose to be any time of seal.
Old Nov 18, 2016 | 12:06 PM
LR03NJ's Avatar
So yours is also dry? Im just afraid that a tiny pebble might got lucky inside.
Old Nov 18, 2016 | 12:12 PM
Red5's Avatar
You're looking at the ring gear for the starter (flywheel). It is supposed to be dry.
You remove the plugs to gain access to the 4 bolts that secure the TC to the flex plate. While you are in there, rotate the crank until each one appears in the open hole and confirm that they are torqued up 'cause they can loosen over time. If they are not, remove, apply blue loctite, and reinstall.
Old Nov 18, 2016 | 09:16 PM
LR03NJ's Avatar
Yikes! too late. I'll keep that in mind. Tks
Externet
Apr 1, 2015 04:22 PM
USAroverman
Feb 11, 2015 06:06 PM
Hapakid88
Jan 23, 2014 11:29 AM
nicke
Jan 30, 2012 05:29 PM
kristokes
Aug 23, 2009 11:23 AM
