My recent engine tick problem and the fix
Old Jul 4, 2018 | 03:11 PM
  #31
Richard Gallant's Avatar
Any suggestions on engine oil flush that can clear those rocker holes, I am coming up on my next oil change so that would be the time to do it.
Old Jul 5, 2018 | 04:13 AM
  #32
JUKE179r's Avatar
Not to change the topic but... I use one quart of ATF in my engine with the old oil, run for about 100 miles and drain the oil and replace filter.
But honestly, just doing regular oil changes and replacing the filter should do the trick.
Old Jul 5, 2018 | 05:39 AM
  #33
shanechevelle's Avatar
No idea. Mine were clogged shut. The PO obviously didnt keep up with the oil changes.
I imagine in less than an hour you could have all the parts off and have the rockers in your hand.
No guarantee it's the issue either.
Old Jul 5, 2018 | 10:10 AM
  #34
Fair enough, but I have buy everything in US dollars with crappy exchange rate, so it starts getting expensive fast. I was thinking more proactive as I don't currently have an issue.
Old Jul 5, 2018 | 01:18 PM
  #35
DKPhoto's Avatar
Really looking forward to trying this, my PS gets randomly stiff sometimes while I’m turning, just started last month. I’ve been trying to figure out the tick from my engine since I got it, after doing everything but checking the sleeves I gave up and figured it was just that. It’s starting to make sense that it would be the power steering pump as it’s from the DS of the engine and I already checked under the valve cover on that side and other than a bit of gunk build up which I cleaned it was fine. Time to go hunting for a new pump... I’ll confirm wether that was the source of my tick when I change out my pump. Hopefully by the end of this month.
Old Jul 5, 2018 | 01:26 PM
  #36
Jeff Blake's Avatar
Originally Posted by abran
Agreed. I have only ever came across one slipped liner.
From what I've read, the 4.0/4.6 never had a slipped liner issue as this casting has a stop on the bottom to prevent that. It was earlier blocks in the 3L range that had the slipping issue.
The primary issue on the 4/4.6 blocks is a thin water jacket wall leading to cracking in the event of a severe overheat, which can only be fixed with flanged cylinder sleeves and an o-ring at the bottom.
The o-ring has always bewildered me though, I mean how are you supposed to put an o-ring into a 300 degree F block with an interference fit and keep it intact?
Old Jul 5, 2018 | 02:08 PM
  #37
Sixpack577's Avatar
The liner can move up on a 4.6.
This has been proven by cylinder markings on the bottom of the head gasket.
Slipped liners may not be as common as thought, but it Does really happen.
After having my engine apart and rebuilding it, it did not appear to have any slipped liners...but I pinned all 8 anyway.
Old Jul 5, 2018 | 03:06 PM
  #38
Dave03S's Avatar
Strike two... I had a block fail through the water jacket and that engine never once overheated, much less severely overheated... You don't need to overheat a 4.6 to have the block become porous at the thin water jackets around cylinders 4/6 and 3/5. It seems just the normal expansion and contraction will do it in some of these thin blocks. This one was a factory replacement 4.6 that lasted 170k ish.
Steven Gray
Range Rover L322 (3rd Gen)
Mar 9, 2022 11:29 AM
Sixpack577
Jul 18, 2017 08:20 AM
EstorilM
Mar 11, 2016 06:33 PM
lordmorpheus
Feb 26, 2015 04:50 PM
Sweetmama
Oct 19, 2009 07:03 PM
