Need help with a leak
Old Sep 19, 2018 | 07:07 PM
  #61
CollieRover's Avatar
Originally Posted by duscarter
0-2
We are now down to a slow drip, it’s coming off the transmission tunnel.
Now it won’t start. No problem before the tear down. I have the battery on a charger
damn. If you go to autozone they will rent you a coolant pressure tester. That way you could investigate the drip without the engine running. Making it easier to inspect and not burn yourself.
Old Sep 19, 2018 | 08:36 PM
  #62
duscarter's Avatar
Thanks Collie, did it before but couldn’t build enough pressure with head gasket and freeze plug leaking.
Old Sep 26, 2018 | 05:06 PM
  #63
duscarter's Avatar
Rented the pressure tester and found 2 leaks. One is the hard pipe that goes into the upper intake. I used an o-ring that I had on hand, it was thinner than the original. It didn't work, so now I have more work to do.
Is there a PN for that O ring? I don't have the original to match it up to. Someone before me had sealed it up with gasket maker.
I did get a few drops from the throttle body. It was minor, so I will do that down the road.
I need to put the knock sensor back on, then may try and start it. I didn't think that would make a difference the last time I tried.
Old Sep 26, 2018 | 09:34 PM
  #64
Rovers North will have the o ring, and do the Throttle body with a Genuine Kit. The Britpart gasket is janky and peels the threadlocker off the threads.
When that system is hot and under pressure, that drip will be a spray faster than you can say I just should have done that when I had the damn thing off.
Old Sep 26, 2018 | 09:58 PM
  #65
duscarter's Avatar
Ha Ha, thanks for the advice. Neighbor stopped by while I was working on it, said " good thing about a British vehicle, you will always be working on it."
Need help with a leak was appropriate for this thread- head gasket, freeze plug, throttle body. The fourth was my fault.
Short work day tomorrow, so hope to try and start it. Knock sensor didn't get put on.
halbertse
Nov 3, 2015 07:14 AM
nuclearw
Aug 11, 2013 04:27 PM
robdis96
Feb 11, 2013 09:30 PM
lipadj46
Jul 9, 2009 04:03 PM
Manj Thind
Jul 3, 2006 10:22 PM
