New D2 Radiator
Old Sep 18, 2013 | 11:13 AM
JimmyTomahawk's Avatar
Defective? What was/is wrong with it? Are they not assesed for quality before being sold? I'm dropping $12 into my new motor and can not gamble on a defective radiator. Should I be looking for another radiator instead of the Nissens?
Old Sep 18, 2013 | 11:39 AM
Nissens is fine. And radiator can be damaged in shipment, have packing material squished inside, etc. First thing I did when I bought my daily driver (Mercedes 93 convertible) was put in a Nissens radiator. They will stand behind their product.
Part of any cooling system work should be use of a borrowed pressure tester, you can pump up to 15 PSI and wait for leaks to show up. No risk the engine as it is not running.
Even the $125 fleaBay special radiators will work better than an oem radiator that is full of Dexcool mud and sludge.
BTW - $12 does not go very far with a Rover motor....
Old Sep 18, 2013 | 11:44 AM
ZGPhoto's Avatar
Yeah it was likely damaged, not from Nissen. I agree with Savannah, the $200 radiator will far outweigh the $12 you're putting into the truck.
Old Sep 18, 2013 | 06:31 PM
Haha! Indeed, nothing costs $12 on these trucks. That was of course meant to be $12k put into the new GPR motor and new coolant system.
Looks like I'll be ordering the Nissens rad then...
Old Sep 18, 2013 | 06:41 PM
DiscoRover007's Avatar
Originally Posted by jfall
yep. Nissen's from Rock Auto.
I followed Savannah's advice and got a Nissens Radiator.
It works perfectly.
I never worry now about over heating ever.
Replaced all three - Thermostat with 180 degree, radiator and I put in a Hayden HD fan clutch which I got from EBay.
No problem since all three replaced.
Do you have issue with noise from the HD fan clutch? Does it sound like a jet engine?
Old Sep 18, 2013 | 10:22 PM
bcolins's Avatar
Default $127 Silla Radiator on eBay
I just put one in my 2003 and it looked and fit identically to the OE rad I removed. However, if I had just paid $12,000 for an engine in my old truck,....I believe I would be installing one of the All Aluminum radiators discussed elsewhere here (The Alu radiator is a Chevy radiator, and there is a bit of light modification required to fit it)
Old Oct 9, 2014 | 04:44 PM
sdhow's Avatar
Originally Posted by Disco Mike
Flush out your engine with distilled water, then add coolant and distilled water, no tap water.
Flush out your engine with imported spring water from Bath. Orders directly from the Queen Mum...
WaldoWilburforce
Apr 13, 2015 01:39 AM
Dan7
Apr 24, 2013 04:16 PM
Rock Sing
Jan 8, 2013 01:51 AM
ebg18t
Aug 8, 2012 05:44 AM
2000 Disco 2 SD7
Apr 16, 2009 10:16 AM
