New Glowshift oil pressure gauge arrived!
Old Oct 15, 2011 | 09:25 AM
anbran's Avatar
Default New Glowshift oil pressure gauge arrived!
10 color Glowshift kit with alarms, etc.
The sending unit on this kit is quite small and I guess it is the best version. It says that the threads are 1/8 NPT. Will that fit into my oil pressure sending port that is originally on there?
Suggestions...?
By the way I had considered the sandwich adapter plate for the oil filter, but wasn't sure if it would fit the LR application...so I figured I would just replace the orig "idiot" light sending unit with the new one.
2002 Disco
Old Oct 15, 2011 | 10:12 AM
0304Disco's Avatar
I have the glow shift oil pressure gauge on both my Disco's. I didn't want to eliminate the factory light so I tapped onto the port just below and to the left of the factory switch. You will need a 20mm to 1/8npt adapter to make this work. You can find these at various places the web.
Old Oct 15, 2011 | 10:34 AM
anbran's Avatar
I'm not sure that there is a port available, as I believe the oil cooler lines are there?!
When you are referring to the 20mm to 1/8 adapter, is that for the way you set that up or are you meaning the original sender port?
Old Oct 15, 2011 | 09:09 PM
I thought many Glow Shift users got the base unit that goes on bottom of oil filter, does not move the oil PSI warning switch....
Old Oct 15, 2011 | 09:39 PM
0304Disco's Avatar
It is for the way I have it set up which I believe is the same way it is set up in the How To Section for oil gauge installation on this forum.
Old Oct 16, 2011 | 12:50 PM
boris_gti's Avatar
You can pull the plug above the oil pressure switch and tap a hole in it. That's what I would do.
See image attached. This is the cover from an '03.
Cheers!
Attached Thumbnails New Glowshift oil pressure gauge arrived!-engine_cover_1.jpg
caymandrew
Feb 4, 2020 08:03 AM
defenderoftheuniverse
Feb 11, 2015 11:31 AM
Jared9220
Mar 12, 2012 02:50 PM
slanginsanjuan
Nov 22, 2011 11:14 AM
lipadj46
Oct 17, 2010 06:34 PM
