The Official Extinct Inline Thermostat Mod Thread
Old Sep 19, 2023 | 11:16 AM
  #421
Richard Gallant's Avatar
@redrover75 I have not yet, but I suspect I will this year as I run cooler most days 177, I figure I will just add a grill cover and tweak that to get a good temp.
Old Sep 19, 2023 | 11:27 AM
  #422
CODisco's Avatar
I just put in a 190° stat a week or so ago. It doesn’t get super hot here in Colorado, but as fall is setting in already (mornings in the upper 40s and daytime highs in the 70s), I was getting that blasted code daily or even several times a day. The 190° stat immediately corrected for that. I’ll keep it in until our temps get back into the 80s here late next spring or early summer.
Old Dec 4, 2023 | 02:44 PM
  #423
Discorama's Avatar
Installed a 192F thermostat in the inline housing for the winter. It makes no mess when you do this little trick:
Create a vacuum in the reservoir. The coolant gets sucked into the system when the housing is opened, only a few drops make it out.
Old Dec 4, 2023 | 05:08 PM
  #424
Harvlr's Avatar
Brilliant idea.
Old Dec 5, 2023 | 09:30 AM
  #425
YETIX's Avatar
What a great idea! And I have one of those from my motorcycling days
Old Dec 6, 2023 | 05:45 AM
  #426
ReignRock's Avatar
Default Amazing product
I’m a new D2 owner but have done a lot of research on them. I know enough to know these things overheat or run at higher temps. But with this thing… problem solved. Before the install I couldn’t sit in the school pickup line without it climbing to 215 or better. One time my check engine light came on. Since the install my rig has seen 180° on my ultra gauge maybe once. Super excited for this!
Old Dec 6, 2023 | 07:50 AM
  #427
NVDiscovery's Avatar
I'm wondering if a 185 degree thermostat would be a good year-round solution except in extreme environments? I'm still puzzled why the 180 degree unit creates the low coolant temperature issues in the cooler (not really cold) weather.
Old Dec 6, 2023 | 08:18 AM
  #428
JUKE179r's Avatar
I’m such a dumb @ss.
I’ve been contemplating installing the 180° or a 190° thermostat and never thought about a 185° thermostat.
Old Dec 6, 2023 | 02:15 PM
  #429
I'm not sure that one exists. It was just an idea to stimulate some discussion. If there is a 185, I hope that it works for you. I'm sure that Extinct can help us to all understand the best options and why.
Old Dec 6, 2023 | 02:45 PM
  #430
Harvlr's Avatar
I installed a 190 (in line) in my P38 last winter. I parked it for the summer so I can’t give any real life input to how it would work in hot weather. My thought is that there should be no more tendency to overheat than a with a 180, as it will be fully open by 190. I wasn’t planning on changing it for the summer.
