ProShaft Front Drive Shaft
Old Jan 22, 2013 | 10:29 AM
  #111
ProShaft-Justin's Avatar
One thing for the guys who don't already have one, please buy a Lincoln grease needle nozzle (or something similar) for your grease gun. This is so you can reach the recessed grease fitting of the CV ball. I can't stress how important it is to keep good grease in this reservoir. The CV ball has needle bearings just like a u-joint cap that need lubrication. This is doubly important due to the heat that the drive shaft is exposed to on the DII.
Old Jan 22, 2013 | 10:30 AM
  #112
ZGPhoto's Avatar
Originally Posted by mongosd2
Well I was being nice...So who's your contact at MDS
WOW, that was you being nice!?!?
Old Jan 22, 2013 | 10:49 AM
  #113
antichrist's Avatar
Pictured in this post, for anyone not sure. https://landroverforums.com/forum/ge...02/#post164811
Old Jan 22, 2013 | 10:55 AM
  #114
ZGPhoto's Avatar
Which one? Will this work? Lincoln Lubrication 5803 Grease Needle Nozzle : Amazon.com : Automotive
Old Jan 22, 2013 | 11:01 AM
  #115
TRIARII's Avatar
Originally Posted by antichrist
That says a lot. You're the kind of drive that be better off with sealed u-joints than greaseable ones. They'll last longer.
If you're not going to religiously grease them every oil change sealed is better.
Anti
You lost me here. Are you implying that greasing the propshaft every 3,000 miles not enough? If so then Id like to know how frequently you grease yours. And do I absoulty need a centering kit? I had hoped just to replace the u-joint with a Precision joint and add new grease and new rotoflex and call it good.
Old Jan 22, 2013 | 11:05 AM
  #116
fishEH's Avatar
Originally Posted by TRIARII
Anti
It's the part where you said "inspect and grease IF needed". Should read "inspect and grease, period". Please try to keep up with the rest of the class, won't you?
Old Jan 22, 2013 | 11:07 AM
  #117
antichrist's Avatar
No. Your "if needed" caveat. You're saying it might not be needed.
It's always needed.
Plus your later comment to "add grease". Doing it correctly is more than adding grease.
Old Jan 22, 2013 | 11:12 AM
  #118
TRIARII's Avatar
It's always needed.
Could you elaborate on the correct way to great a nipple then? I already know that you need to grease each u-joint until grease seeps from all 4 seals. and I planned on installing the replacement u-joint in the same exact position as the original u-joint (on rear shaft).
Gotcha about "if" obviously I have the right idea just bad choice of words. But is re-greasing every 3,000 good enough?
Old Jan 22, 2013 | 11:13 AM
  #119
Originally Posted by ZGPhoto
Zack,
Yes, that's the one I've always used.
Old Jan 22, 2013 | 11:19 AM
  #120
antichrist's Avatar
Read the propshaft rebuild post.
