Ready to buy MAF
Old Dec 7, 2010 | 12:53 PM
  #31
bosshogt's Avatar
texmbr,
Did you get a check engine code for the MAF to let you know it was bad? Just curious. I've heard they are on borrowed time at about 100k. I have a spare in my parts collection.
Old Dec 7, 2010 | 04:35 PM
  #32
texmbr's Avatar
I did..0173, 0174, and 0733 all MAF codes. The one I took off mine and put on my wife's 01 came off mine with 119,00 and it is still in her car and no codes. I put her's on mine (the one showing codes) to test it and got the codes after one drive cycle. I cleaned it with MAF cleaner..let it dry and put it back on and worked good for several days. Maybe 200 miles of driving then I got the codes back. So I went to replace it and was talked into a aftermarket one cause it was cheaper. It gave codes after one drive cycle but the vehicle seemed to be running great. Took it back and payed the difference and bought the correct Bosch MAF and have not had a code since. That's the story.
Old Dec 7, 2010 | 06:25 PM
  #33
jkid's Avatar
Yes, don't be cheap on a new MAF sensor. Make sure to get the Bosch sensor. I got a cheaper aftermarket sensor (the box said Lucas on it) from a reputable parts dealer when my sensor went bad and it didn't work. I ended up replacing it twice with no success. I finally got a Bosch from AB (I tried their aftermarket sensor too with no success) and my codes went away. Talk about frustrating, it was driving me nuts.
Old Dec 7, 2010 | 08:18 PM
  #34
Babysdisco's Avatar
I just bought a 01 Disco and they told me I need a MAF sensor too and advised on a used one. Any thoughts on that? What are good web sites for used parts for this vehicle? I also need an ABS pump for my amigos!!!
Old Dec 8, 2010 | 08:31 PM
  #35
texmbr's Avatar
Do you have a check engine light on? If so what are the codes it is throwing?
Old Dec 9, 2010 | 06:54 AM
  #36
hilltoppersx's Avatar
dont buy a used one. if you want a cheaper way out then having to buy a LR specific MAF you can use the VW Bosch equiv its part # 06A906461A its $70 but you need to wire the intake temp sensor separately.
Already a Rover
Mar 31, 2015 11:05 PM
cobbcj7
Jan 21, 2011 03:13 PM
starrock
Jan 18, 2010 04:34 PM
jasons
Aug 11, 2009 10:09 PM
DeShawn
Apr 14, 2008 11:27 PM
