Rear Air Suspension problem 03 Disco
Correct its best done with 1" or 2" spacers under the air springs. But until you can get those you can also adjust the hight temporary by raising the height sensors on the rear trailing arms. I used once section of metal pipe strap to space up 1".
Here is the 2" spacer kit you might consider from ToddCo Suspension.
http://store.toddcosuspensions.com/larodiiisls2.html
How so? I had my Range Rover that would only leak when in highway mode and of there someone in the rear seats. There was a crack that would leak just enough and that would cause a gard fault and drop to the bumpstops. It was nothing electric about that. I am just throwing out ideas to maybe find the solution.
i have the same exact problem. will sit fine in driveway for weeks and then deflate in a parking lot or on the highway. I replaced the bags, they had plenty of dry rot and needed to be replaced anyway, but I still have the same problem. Electrical system is next. If you replace the bags, don't count on it solving your issue.
My truck would sit down on the bump stops after parking in cold weather. I raised the truck...pumped up the bags so I could see the entire bag surface. Then sprayed with soapy water and bingo it was worn out and leaking under the fold of the airbag. The leaks will show themselves if they are there. $265 dollars and about an hour per side and the Arnott bags were in and no issues since then.
What are the common electrical faults with the system?
If you find the bags are leaking, don't get frustrated... Very easy fix to swap out bags...
Depending on the parts you need this may save you more than eBay or Amazon.
For a limited time you can also use code ' RoverForums ' to save 10% off purchases (up to $75 max discount) when buying off the Arnott web site store. Offer ends July 1, 2012.
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
