Rear Differential Lock
Old Jul 24, 2021 | 05:57 PM
rikkd's Avatar
Default Rear Differential Lock
I ordered a rear diff with a TT locker already installed. I need to install it and send back my original diff. I was curious to see how long it took others to put it in and if anyone had any advice.
Old Jul 24, 2021 | 07:03 PM
redwhitekat's Avatar
where did you buy it from ? I’m toying with the idea of putting a true track back there
I had read reviews of folks being happy with a front and rear TT only locks when you need it
Old Jul 24, 2021 | 09:46 PM
tnrangerover's Avatar
what size tires do you have? I’ve read many reports that it starts to lose locking efficiency at 32 or 33 inch tires. It is much stronger than the stock carrier though, so still an improvement.
Old Jul 24, 2021 | 09:50 PM
id start in the morning with all the right tools ready and assume you could have it done a bit after lunch, but maybe sooner. If nothing else, just block out the entire day and you should be set. It definitely shouldn’t take longer than a day.
you’ll want to just unbolt the entire hub and axle shafts in one and slide them all out. Don’t fool with the huge axle shaft nuts if you can help it. You’ll need silicon for the punk in. Good time to replace your rotoflex as well.
Old Jul 25, 2021 | 12:25 AM
rikkd's Avatar
Bill from Great Basin Rover
Old Jul 25, 2021 | 08:10 AM
Alex_M's Avatar
I did a write up about 5 years ago on how to replace the diffs. Should be of help to you.
https://landroverforums.com/forum/di...76/#post563832
You do not need to bleed the brakes after, not are there any required gaskets except some RTV. All in all not a bad job at all.
Old Jul 25, 2021 | 01:52 PM
rikkd's Avatar
Thank you so much!
Old Jul 25, 2021 | 05:51 PM
cvhyatt's Avatar
Alex’s write up is fantastic. I followed it with great success a couple of months ago. Pretty straightforward even for a noob like me.
https://landroverforums.com/forum/di...39/#post766269
flyer08
May 2, 2021 09:11 PM
flyer08
Jan 23, 2020 11:22 PM
grandkodiak
Jan 4, 2012 09:09 AM
XFcat
Nov 16, 2007 11:05 AM
handsome rob
Feb 14, 2007 07:15 PM
