Rear door subwoofer EXACT FIT replacement JL Audio 6.5" component woofers
Old May 6, 2015 | 12:04 AM
  #31
cimomd's Avatar
Originally Posted by Dinoco
Please tell me they fit and sound like butter.
They fit perfectly and sound like buttah !!!! exactly what I was expecting. In fact the higher the volume the more response I get out of these woofers with minimal to no distortion. The sound is like night and day, hate using that term but the sound from the stock HK woofers does not compare to the JL C2's. I am very happy with these. The clarity, bass response, and overall sound dynamics nearly rivals my Harden Kardon Logic 7 in my C class which I consider the ultimate stock system imo.
Old May 6, 2015 | 07:17 AM
  #32
I picked up a set of renegade 6.5 components for $35 off egay. Also a perfect fit, sound I'm sure is no where near the JL, but they sound good enough for me and better than they did.
Old May 6, 2015 | 07:30 AM
  #33
cybercop's Avatar
RF makes some good stuff. Should be nice.
Did you just take the woofers from the set and put them in the rear "sub" box, or did you put them in the front doors?
Has anyone tried the JLs in the front doors?
Old May 6, 2015 | 08:14 AM
  #34
I just used the woofers in the rear door sub box. My fronts still seem good, so for now I'm going to leave them alone.
Old May 6, 2015 | 09:35 AM
  #35
abran's Avatar
Did you replace all 4 doors with these or the rear box? Also what is the item number, seems there are a few.
Thanks
Old May 12, 2015 | 09:37 AM
  #36
Big Jim Swade's Avatar
Well, I got the set of JL Audio C2-650 woofers installed in the cargo door last night. Are they better than the stock speakers? Yes, but I was expecting more. The stock speakers from my "High Line" system are some pretty high quality for OEM speakers and have larger magnets than I thought they would. I don't know if I would recommend replacing them without going to a larger size. I think the rear cargo door speakers just has too much low frequency bass from the head unit going to them for any 6.5" speaker to doo much with.
Old May 12, 2015 | 04:31 PM
  #37
cybercop's Avatar
The two Tang Band 6x9s I put in the rear will shake your truck apart. Well almost :-)
Old May 13, 2015 | 10:36 PM
  #38
Joemamma1954's Avatar
Has anyone replaced the 6.5" door speakers? I know I replaced my two in the rear sub box, and bought two more for the back doors, and found they were NOT the same as the ones in the rear box. First of all they have a special connectors on them, and second, they are held on by three screws which do not line up with any of the holes on the new speakers. Third, the hole in the door will have to be made larger, or a spacer of about 1/4 to 1/2", kind of like Cybercop did to install in his front door. All I am saying is, the door speakers are not the same speakers that are in the rear sub box.
Old May 15, 2015 | 06:27 PM
  #39
I ordered spacers for the back two 6.5s and they will be here next week, and also ordered some speaker wire adapters that i can modify to fit the oem fittings, I will post pics of all if they work.
Old Jun 1, 2015 | 01:06 PM
  #40
cimomd's Avatar
Thanks
I replaced all the 6.5's in the vehicle, 2 subs and the 4 doors. Left the midrange and tweeters alone. And I must say that as long as you can find 4 ohm component woofers that are 6.5" they will likely work fitment wise and sound good. Im not pushing JL's, I'm just real picky about bass and my research led me to JL audio. Those damn MB systems screwed up my ears ))))))) in a good way
cimomd
Audio/Visual Electronics
Mar 5, 2022 08:38 AM
jycsalas
May 23, 2019 03:02 PM
Rover_Hokie
May 27, 2012 09:37 PM
rrhyne
Jun 7, 2009 06:02 PM
