Replace Wires Without Removing IM
Old May 28, 2010 | 05:28 AM
  #101
rrc.swb's Avatar
Originally Posted by Henry Driver 3
I was changing plugs on my wifes 2003 disco 2 and cant get one of the plugs to catch a thread when putting in new one . tried every angle and still no go. plug hole threads appear to have some debris on them which i am trying to clean out with a dental instrument. plugs were hard to get out and this happened on plug 6 of the 8. advice anyone?
Henry
Did you try tightening the plug with a plier? (do it carefully)
That happened to me while doing mine ('03 DII).
Old Jun 2, 2010 | 10:42 PM
  #102
mcgyver210's Avatar
The instructions here are GREAT & very easy to follow. Actually the wire change out wasn't as bad as I thought it would be. Although I still think who ever put the Coil Pack next to the Firewall should be severely punished.
Side note I also ended up replacing the front O2s same time for some reason after wires & Plugs.
Old Jul 1, 2010 | 01:15 PM
  #103
Robeye's Avatar
6th Gear
Just popped over from Landroversonly.com and must say...well done. I saw how these wires were going to be a pain in the neck and am glad to see someone had some details on how to change them. I hope to do it without busting a few knuckles open and keeping my sanity at the same time.
Old Jul 8, 2010 | 07:40 AM
  #104
martinsthree's Avatar
4th Gear
Originally Posted by grussell
I had a 2001 for a short time and changed the wires without removing the IM. I have large hands and did it in about 1 1/2 hours. I removed all of the wires and then installed the lower bank first and then the upper bank. I still had a misfire and removed them and reinstalled again to make sure they were correct. The second time it only took about an hour. The pictures will help you. I found it harder to remove the old wires from the coil pack than installing the new ones.
Since you didn't post again, can I assume reseating the wires resolved this issue? I have the exact result after replacing plugs and wires. Mine is a misfire on #4. Had to replace the wires since the one on #4 was faulty and was arching nearly all along the wire. My best guess is that the resistance change from arching fried that terminal on the coil. I ordered a single coil pack from Advance. Very much dreading replacing the pac, wires were difficult enough. But I did it without removing the IM. Here are some things I learned
DO - slide the Secondary Air tubes to the passenger side, and lift out the driver side single tube first. The dual tube passenger end straddles two coolant tubes and it's easy to lift the single tube side up and toward the double and wiggle up and out from there. Replace the same way. DO - lay on your engine from front to rear to access the coils. DO - tighten four accessible valve cover bolts while you have pieces off, they loosen over time. DO - start by removing the neg batt lead. DO - dump debris from the catch "tank" on the bottom of your Mass Air Flow Assembly while off (I had dirt in mine). DO NOT - loose patience or confidence. My first time with a project like this. You'll be proud when you get it done. Spend your saved money on a party after.
Anyone here think I'll have problems replacing one of the two coil pack with a $62.00 aftermarket replacement?
Old Jul 8, 2010 | 10:24 PM
  #105
4th Gear
Did it! Truck is running great now. The coil pack was the problem. I really wish I was that guy. The one who wants a big truck because I'm small with a complex. Next time I remove the intake Manifold, there is not much room back there to wrench. Couple notes if you try.
Replacing one of the two packs works, short term diagnosis only. If you replace the whole assembly you will need to remove the IM. I was able to take the one I removed out by wiggling it toward the passenger side. Of course the secondary air pipes were off.
1/4 inch drive(small is needed), universal adapter, 2 and 5 inch ext(3 and 5 would have been slightly more comfortable), and an 8 mm slim socket worked for me. All bolts on the coil pack are 8mm. Secondary Air pipe connection to the bracket is 10mm, bracket connects to the engine with 8mm.
I plan on having this great truck for some time, cause I luv it. Could everyone who succeeds at a task post how to and best practice? I will.
Old Jul 14, 2010 | 11:25 PM
  #106
245 sleeper's Avatar
5th Gear
Hey guys just ran into a problem while installing a new coil set. i need to know what size screw is used to hold it in place.
please help
Old Jul 15, 2010 | 07:23 AM
  #107
4th Gear
It's 8mm
Old Jul 15, 2010 | 07:51 PM
  #108
5th Gear
thanks Martisthree, I just finish changing my coil and i did not remove the IM, Its hard but you can inch it out towards the passenger side and got it back in the same way. Regarding the bolt on the coil to the bracket, mine is not 8mm but its a bolt w/ philip screw not flat head screw if that make sense.
Old Jul 30, 2010 | 03:16 PM
  #109
denisk's Avatar
3rd Gear
Default Plug wire #4 got loose... far away from home (Disco 2)
Originally Posted by DeepBlueWater
2003 Discovery Wire Replacement
Yes, it is possible to replace the wires on your 2003 or similar Disco without removing the intake manifold. And it’s not that difficult.
MWmG
Dear all, I had a misfortune of hitting an unpainted sharp speed bump last night on my 2001 Disco II, it started running rough, SES light came on flashing. Upon seeing an arch between the coil pack and firewall I established the #4 wire is hanging loose (the second in the lower row). Spent much of the day today laying on the engine trying to get the wire back to no avail... The lack of space plus the other wires in place make me think its an impossible task, without taking half the engine apart. Please share your thoughts, i'm in Outer Banks, have to head back home to DC tomorrow... Is it safe to drive on 7 cylinders? Many thanks in advance!
Old Jul 30, 2010 | 03:25 PM
  #110
Bundu's Avatar
Banned
I would not drive like that. Get a long thin screw driver and bend it in kinda a J shape to get at the wire and push it in.
Look under "Write ups" and "How To" at the write up about changing wire without removing the IM, you'll get the idea.
