Spare tire swingaway for Greg Davis bumper?
Old Apr 11, 2018 | 10:45 AM
  #51
JohnHZ3's Avatar
Originally Posted by Alex_M
I just saw this reply.
That's good info. I end up towing a LOT so I guess I'll probably end up with the 4.56s. Gotta get that axle breaking torque transfer.
Last year I towed a car on a two axle flatbed from Southern California to Northern California and back. Didn't break any speed records and the rear springs definitely compress a bit with the trailer. With the lift the Rover is not exactly the ideal tow vehicle but it did okay.
Attached Thumbnails Spare tire swingaway for Greg Davis bumper?-20170821_123157.jpg
Old Apr 11, 2018 | 11:10 AM
  #52
Sixpack577's Avatar
Does that have a galvanized frame!?
Old Apr 11, 2018 | 11:27 AM
  #53
JohnHZ3's Avatar
Yes it does.
Old Apr 11, 2018 | 03:39 PM
  #54
Alex_M's Avatar
That's a nice looking trailer, and car. That spring compression issue is why i'm looking to go to a heavier rear spring also. I end up towing with my Disco at least once a week. Sometimes more often; i:'ve towed every day for a week+ before. Most I've had behind her was 7300lbs on curvy mountainous roads, without any trailer brakes.
These trucks don't win any towing awards, but if you know how to tow pretty well then they are extremely capable.
Nice galv frame. Your rig has all the goodies looks like.
Old Apr 12, 2018 | 02:57 AM
  #55
The Deputy's Avatar
Yeah, looks like it came with a very nice "passenger seat" option, too.
Also, looks like your car is a little to far forward on the trailer, by looking at fender to wheel clearance. Definitely could move it back a few inches to level load over trailer axles, and in turn help your rovers suspension immensely...and it will pull so much nicer.
Brian.
Old Apr 12, 2018 | 07:04 AM
  #56
Sixpack577's Avatar
Yes it does.
Did you raise the body off the frame on a lift?
Any details on the swap?
Old Apr 12, 2018 | 11:37 AM
  #57
JohnHZ3's Avatar
Brian.
That particular passenger seat option has been on board with all my vehicle purchases so I am very lucky.
The car may have been slightly far forward on the trailer but I think it might be the camera angle. Thanks for the tip. I will check it out next time I load it up.
The guy who started modding it installed the galvanized frame after the original frame cracked due to rust damage. He did have a lift I believe so I'm sure that is how he did it. Unfortunately he didn't take any pictures of the process.
Old Apr 18, 2020 | 04:04 PM
  #58
Romose's Avatar
Default Swing out tire carrier
I have been planning on doing this for a few years and finally got around to it thanks in part to this thread. The rear door was already damaged prior to my ownership and was difficult to close. The tire is 315/75R16 which is obviously way too heavy to be mounted to the door. I looked into all the parts offered for sale but decided none were exactly what I wanted. I liked the bushings of the Iron Pig spindle and the dual shear bracket of the Comp 4x4 version. I also liked the idea of a sleeve welded into the bumper rather than welding the spindle in place. This will allow for easy replacement or removal of the spindle in the unlikely event in gets damaged.
After measuring numerous times I drilled through the top and bottom of the bumper using a 2" hole saw. Then using an angle grinder with a cutoff wheel I connected the two circular cuts. A piece of 2" OD 1-1/2" ID tubing was tack welded as squarely as possible into the cutout. The hinge pin is 1-1/2" diameter steel. The carrier pivot is 2-1/4" OD 1-3/4" ID tubing with bronze bushings inserted (which were removed and replaced with new ones after welding). The frame is constructed of 3" x 1-1/2" (1/8 wall) tubing and 1-1/2" x 1-1/2" (1/8 wall) tubing. I added a dual-shear bracket to the pivot point to increase the rigidity. I modified and reused the mounting bracket which had been installed on the door for the rim mounting. After welding and mounting the carrier frame, I was disappointed by the amount of flex/bounce with the tire installed. All the flex was in the bumper itself and not the carrier or hinge. I ended up making an additional bracket, which mounts in the stock location on the door, to anchor the carrier to the door. It also doubles as the antennae mount. All the weight is still on the bumper. Everywhere a structural bolt mounts to the bumper I installed a rivet nut insert for added strength and grade 8 hardware was used. I am pleased with the appearance and strength. Having to loosen 3 screw-in handles is a bit cumbersome to open the carrier but ultimately I decided it was more important to have it securely attached.
Any possibility i could contact you for more info. I am currently having a tire carrier built for me and we could use some clarification and insight.
Old Apr 18, 2020 | 05:14 PM
  #59
JohnHZ3's Avatar
No problem. Hopefully I remember the details! I sent you a message.
KingKoopa
Oct 29, 2017 11:20 PM
Jcbe34
13
Apr 3, 2014 09:04 PM
aftermath431
Sep 23, 2013 08:17 AM
ZGPhoto
Aug 14, 2013 11:13 AM
A5scott
Aug 26, 2012 09:13 AM
