Stake Nut Removal Help
I have the 32MM driver for the stake nut, but cant get anything to bend that tab to take the nut off.
Any suggestions for a tool to do this with? Do you just get a screwdriver in there and whack it?
i am trying to take the hub off
thanks
thanks
Was able to break the nut...thanks guys.
Next question...do i try to reuse this thing? If so, then I guess I need to tighten to the same spot and whack that tab back in again.
thoughts?
thanks
matt
thoughts?
thanks
matt
I reused mine because it was never really staked on in the first place, just a little bent in. If it was actually staked well before you should really replace it though:
http://www.roverparts.com/Parts/CDU1534L.cfm
Maybe I got lucky because mine lined right back up without trying. Like I said though none of mine axle nuts were really staked, I did not even bother to unstake it before taking it off. Maybe the guy responsible for staking was sick that day. During my last brake job though I restaked them all.
