Stuck diff stick
Old Mar 23, 2007 | 11:16 PM
werldcup's Avatar
Default RE: Stuck diff stick
What exactly are you doing when trying to shift over into lock? It helps if you are rolling forward ~5mph in neutral and shifting over.
Old Mar 23, 2007 | 11:53 PM
jwmstang's Avatar
I am just sitting still on flat ground. I have just now gotten the stick to move and I was testing everything
Old Mar 24, 2007 | 12:26 AM
greg409's Avatar
The high/low function is the pivoting part of the linkage & you can generally get it operating easily again.
The diff lock (awesome) function is same linkage (basically) only a sliding function and usuallyrequires some afternoon dissassembly then regular use to maintain functionality.
You'll like it!!
Old Mar 24, 2007 | 12:47 AM
jwmstang's Avatar
where can I find disassembly instructions? I have an official workshop manual but I can't find where it is in there.
Old Mar 24, 2007 | 12:57 AM
werldcup's Avatar
I'm not 100% on this but it may require removing the center console, drilling out the rivets holding the transmission blanking plate and going at it from above.
Old Mar 25, 2007 | 12:22 PM
greg409's Avatar
jwmstang - try -land rovers only dot com
go to - stuck diff lock
I don't recall if it's under disco or not
(my link bypasses the mainpage)
Good luck
greg
Old Mar 25, 2007 | 02:09 PM
werldcup's Avatar
Check out this site, it has a good tutorial on fixing it.
Old Apr 16, 2007 | 01:47 PM
johnkbl's Avatar
Have you fixed your problem? I fixed the same problem last week, and I an help if you need. Please let me know.
ImQuattro
May 1, 2014 08:36 PM
hriant88
Aug 6, 2013 05:09 PM
rs200nz
Apr 10, 2008 03:20 PM
alrd
May 25, 2007 07:18 AM
toms_disco
Dec 10, 2006 07:29 PM
