Stuck removing alternator pulley
Old Jan 26, 2013 | 04:02 PM
cipher982's Avatar
Default Stuck removing alternator pulley
Hey guys, trying to replace the bearings on my alternator to fix this awful whining noise, but I've spent the better half of my afternoon trying to get the 22mm nut off the alternator pulley. Are there any special tricks?
The guide here just says stick the internals in a vice:
https://landroverforums.com/forum/di...ssembly-51103/
I've tightened my vice down at much as I can and even using a breaker bar on my ratchet I still can't budge the nut. It eventually just pops out of the vice. Also used some penetrating bolt remover spray.
Old Jan 26, 2013 | 09:04 PM
Is it threaded reverse direction?
Old Jan 27, 2013 | 08:05 PM
jfall's Avatar
Oui.
You will need a new alternator soon.
Denso is the way to go.
British Pacific has them about $250 or so.
You may get it yourself and if you do - hats off.
Old Jan 27, 2013 | 08:08 PM
BrandonS's Avatar
An impact gun may help. Sometimes the pounding of the impact will break it free where as the progressive force of a breaker bar won't.
Old Jan 27, 2013 | 09:47 PM
Jared9220's Avatar
An impact gun is the way to go. I was able to hold the pulley with my hand (with a glove on) and break it loose with my impact gun.
Old Jan 28, 2013 | 07:30 AM
drowssap's Avatar
x3 An impact gun is the way to go
Old Jan 29, 2013 | 10:19 PM
cipher982's Avatar
Well I tried some suggestions, to no avail. I had a little 18v impact, didn't do much at all. Then borrowed an air gun and hooked it up to my compressor, and that just yanked the alternator right out of my hand and the vise. Tempted to just cut it off at this point, and try and find a replacement nut somewhere. Or drop it off at some shop and just hand them $10 to knock it off if they can.
EDIT: maybe heat it up with a propane torch for a bit? I'll go try that in the morning.
Old Jan 30, 2013 | 06:02 AM
drowssap's Avatar
drop it off at some shop, it realy should not be that much of a task to get it off
lrjon
Jun 7, 2020 04:13 PM
ImQuattro
May 1, 2014 08:36 PM
0304Disco
Dec 10, 2010 03:26 PM
awer25
May 3, 2010 12:41 PM
lipadj46
Nov 15, 2009 07:09 PM
