Transmission oil issue
Old Nov 27, 2012 | 05:57 AM
ratijs100's Avatar
Originally Posted by Seneca
where is the best place to purchase transmission coolant lines?
Generally I do parts shopping on roverparts.com or rockauto.com.
So, try to find there.
Old Nov 27, 2014 | 10:23 PM
OilPatch's Avatar
Is dextron 6 okay to use on our transmissions? I've got a couple ou extra gallons laying around that were extras from my raptor flush
Old Nov 28, 2014 | 02:05 PM
Fast951's Avatar
Read the bottle to see if the manufacturer states your product is backwards compatible with Dextron III. If so it should be no problem, it may actually be an improvement.
Old Nov 28, 2014 | 05:04 PM
ewbourne's Avatar
Default tranny flush and fill
Is a mechanical flush and fill better/worse option on a tranny with. 100,000 miles and unknown maintenence.
Old Nov 28, 2014 | 06:02 PM
Fast951's Avatar
Regardless of maintenance history fresh fluid is never a bad idea. Make sure you change the filter, O-rings and pan gasket when service is performed. I'm not a fan of those power flush procedures since they usually disconnect cooler lines to attach their flushing equipment. This can result in broken connectors and/or leaks when lines are reattached.
Old Nov 29, 2014 | 08:37 AM
Babymog's Avatar
I have a couple of friends with auto-transmission rebuilding shops, and they tell me that transmission flush machines are their best referrers. If not used perfectly properly, they can damage the transmission seals etc., and my friends are used to people coming in and telling them that they just had the transmission flushed and now it won't shift or other problems (neither of them will do or recommend "flushes"), and it is now rebuild time. Many flush shops will tell you that the flush just cleaned it out and it was about to fail anyway, ... I've heard this story many times also.
If you choose the flush method (I'd rather run old fluid until I find a shop that will do it the correct way and drop the pan / change the filter & fluid), do not do it at an oil-change shop or other general service shop, have it done by a real auto-transmission specialist (who will probably tell you that they don't "flush", they only do it the right way).
Old Nov 29, 2014 | 10:02 AM
drowssap's Avatar
The power flush does not change the filter which by now with 100k it needs
Old Nov 29, 2014 | 09:33 PM
jfall's Avatar
Put in Synthetic Dextron type of trans fluid.
I also threw in a can of Lukas Transmission Anti slip stuff for good measure.
Be sure to fill the trans with engine runnng in "N".
Don't burn yourself on the cats.
Old Dec 2, 2014 | 11:48 PM
Fast951's Avatar
Originally Posted by jfall
....Be sure to fill the trans with engine running in "N"...
This is interesting - I thought I read to refill with the transmission in Park, then with your foot on the brake cycle thru the gears a few times, then back in Park and top-off.
Can you expand on the difference between refilling in N versus P?
Beaulim
May 2, 2014 08:03 PM
Kingmarine
Feb 26, 2012 09:27 PM
Maximuse34
Jan 1, 2008 03:35 PM
01discosteve
Sep 17, 2007 05:33 AM
superderek3
Dec 18, 2006 12:09 PM
