Valve Train question
Old Jan 29, 2018 | 10:08 AM
328Driver's Avatar
Default Valve Train question
So I decided to pull the valve covers off the D2 to replace the gaskets. I noticed that all the rocker arms are in the same position except cylinder #6. It has one spring that is slightly compressed and the arm is about 1/4" down compared to the rest of them. Is this unusual? It hasn't been run in about two weeks. B.t.w. it does have a tick that I think comes from that side when it warms up.
Thanks guys
Old Jan 29, 2018 | 05:47 PM
number9's Avatar
Not for an engine with hydraulic lifters once the oil drains out from not running in some time. You may also have one ore more lifters that don't pump up enough causing a tick.
What weight oil are you using?
Old Jan 29, 2018 | 06:51 PM
328Driver's Avatar
I'm running Rotella T5. Shouldn't that one rocker's lifter drain back so there is no compression on the spring?
Old Jan 29, 2018 | 07:31 PM
number9's Avatar
10w-30 or 15w-40? Some LR ticking issues are helped by using a heavier oil.
The lifters don't disappear when fully compressed and still provide push rod lift. Not all lifters leak down at the same rate. One of the valve train gurus may have more specifics on your #6 cylinder valve if you provide the piston's cycle/position.
Old Jan 29, 2018 | 10:04 PM
328Driver's Avatar
15w-40. Question is that they should all drain down right?
Cylinder #8 is DTC
Davis31052
Nov 21, 2017 11:41 AM
jamieb
Jan 16, 2016 07:37 AM
Disco Mike
Jun 21, 2012 09:32 AM
Disco Mike
May 27, 2011 09:29 AM
hubris
Dec 14, 2007 09:31 PM
