Valve Train question
So I decided to pull the valve covers off the D2 to replace the gaskets. I noticed that all the rocker arms are in the same position except cylinder #6. It has one spring that is slightly compressed and the arm is about 1/4" down compared to the rest of them. Is this unusual? It hasn't been run in about two weeks. B.t.w. it does have a tick that I think comes from that side when it warms up.
Thanks guys
Thanks guys
What weight oil are you using?
The lifters don't disappear when fully compressed and still provide push rod lift. Not all lifters leak down at the same rate. One of the valve train gurus may have more specifics on your #6 cylinder valve if you provide the piston's cycle/position.
Disco Mike
Jun 21, 2012 09:32 AM
Disco Mike
May 27, 2011 09:29 AM
