What is this called?
Old Apr 8, 2010 | 10:35 PM
Danny Lee 97 Disco's Avatar
Originally Posted by GARovee
Nothing as long as you can still shift the transmission and operate your HDC, TC, and high/low. The light on the dash just won't come on when the case is out of gear.
I understand TC as transfer case and the high/low shift.
1. What is HDC. Not familar with that term.
2. Never had such a light, just the Diff Lock liht when it engaged.
Please explain.
Old Apr 8, 2010 | 10:57 PM
greg409's Avatar
I believe you'll get an obnoxious buzzer/chime if you put it in gear with the transfer case in neutral because of the switch.
luck,greg
Old Apr 9, 2010 | 11:09 AM
so is that what yours does? I couldn't get a continuity reading across it no matter if the plunger on it was in or out. It probably went bad just like the CDL switch did. If that is the case, it has not worked the entire time I've had it.
Old Apr 15, 2010 | 07:20 PM
Default X175 Transfer Position Box Position Switch
I finally came across this when I was perusing the Component Location listings recently:
X175 Transfer Box Position Switch and the associated connector is C368
I do not yet know its functionality or the effect of having it physically installed but not electrically functional.
The quest for specific knowledge continues. Any and all input/comments appreciated.
Arcon Blanc
Apr 19, 2010 10:10 PM
sk_adams
Mar 20, 2010 06:07 PM
JBEGIN
Jun 30, 2009 09:10 PM
aublec22
Jun 10, 2009 06:27 PM
OxyCoRover
Feb 13, 2008 04:31 PM
