Old 12-09-2013, 02:35 PM
mwelton's Avatar
West System epoxied my peeling dash edge back into place.
  #1062
Old 12-10-2013, 06:43 AM
drowssap's Avatar
pulled the intake to replace coils, wire, plugs & 02 sensors pretty straight forward
  #1063
Old 12-10-2013, 11:19 PM
Street Wolf's Avatar
Removed the belt driven cooling fan and replaced it with electric fans.
  #1064
Old 12-11-2013, 12:15 AM
Madlands's Avatar
What fans did you go with and did you use a thermo switch to control them?
Been thinking of doing the same down the road so I'm really interested in the details.
  #1065
Old 12-11-2013, 02:03 AM
SD4x4's Avatar
5th Gear
Installed a 300 watt led light bar
  #1066
Old 12-11-2013, 11:49 AM
Yep, I have it hooked to a coolant temperature switch in like on the radiator hose. Also the fan is from a 1999 Impala Police package. Relatively the same as any dual fan setup from any 3800 powered car, but heavier duty for police use. Perfect fit for the Disco too.
Police package Impalas can be hit or miss though. Any "W-body" care around that year range will have relatively the same fans however. Grand Prix, Monte Carlo, regular Impala, Buick Regal/Century, etc...
  #1067
Old 12-19-2013, 01:49 PM
Daedrix's Avatar
Replaced all exhaust gaskets/studes, o2 sensors, and valve cover gaskets.
  #1068
Old 12-19-2013, 07:40 PM
CBRacerX's Avatar
Installed used cup holders and a new style brake light switch. Also ordered parts for an oil pressure gauge and researched a front driveshaft replacement.
  #1069
Old 12-21-2013, 03:56 PM
acamato's Avatar
I created more work for myself... Not happy.
I decided since it was over 50 degrees today, I would replace my power steering return hose. I pulled the ac/ace/ps bracket to get to the clamp on the bottom of the ps pump. The bracket fell form where it was propped up and hit the radiator putting a hold in it.
I started following the RAVE to pull the radiator out of my 99 parts DII and my 00 DII , I got the the trans/oil cooler lines. What a PITA. Searched and found some tips that I can separate the coolers form the radiator in the DII. I will try to finish tomorrow.
Hopefully the radiator out of my parts DII will still have me running at 194 degrees.
  #1070
Old 12-22-2013, 08:22 AM
Chrisinhouston's Avatar
Glad to see you are raising that child up to appreciate a Land Rover!
Quick Reply: What did you do with your DII today?
