#1201
Haven't moved mine on over week since I broke a motor mount and the fan exploded. (The fan took out the radiator, upper shroud, coolant return line, air box, and parts of the fan tried to punch up through the hood.). Then the shaft on the PAS pump decided to walk out about 4mm and shreaded the belt, so...
...in the last week I've done the following:
- Replace the radiator, fan, fan clutch, cooling return hose.
- Flushed and bled the cooling system.
- Replaced 2 motor mounts.
- Made a custom, 5-rib belt to get the truck home when it tried to slice 2 ribs off the existing belt. (All I did was trim the rest of the 2 ribs off, but I did it on the side of the road in the middle of the night!)
- Pulled and replaced the PAS pump with a brand new one.
Today,
- I'm re-bleeding the cooling system (temps just weren't stable enough for my liking before the fiasco with the PAS).
- Bleeding the PAS pump.
- Maybe (time permitting) replacing the rear drive shaft with a u-joint rear drive shaft. (I'm just tired of wasting $$$ on rotoflex couplers.)
Today,
#1204
Rained a little today, tried using my wipers to just clear the windshield, and they made it worse. I didn't want to buy new wiper blades from the interweb, so I went to AutoZone and bought some Bosch 21'' Blades and swapped the rubber pieces onto my the LR frames. Took 15 minutes and some finesse, but they work great.
#1205
#1206
#1207
#1209
