Old 04-19-2014, 10:20 PM
Dane!'s Avatar
finished the bumper, roof rack or rear bumper next weekend.
  #1642
Old 04-19-2014, 10:53 PM
Dane!'s Avatar
Damn that's a terrible picture... I guess its good considering how destroyed my phone is though
  #1643
Old 04-19-2014, 11:24 PM
zeroone's Avatar
Looks pretty good. Like the red rover in the background. Wish mine was red.. or blue. Chawton white would have been nice. stupid zambezi silver. Lol
  #1644
Old 04-19-2014, 11:25 PM
zeroone's Avatar
Originally Posted by SuperSport
That looks great. My rubber mat is still good, but I'm noticing wear on the brake boot. Time to change those out. I like yours, nice look with the stitching.
Thanks! Cheap on ebay. Nice thick leather too. Thought the stitching would add a nice detail.
  #1645
Old 04-20-2014, 06:25 PM
Jared9220's Avatar
I adjusted the parking brake today. It has to be one of the most simple repairs to do on this vehicle and it made a big difference.
Here are the instructions from the RAVE.How to Adjust the parking brake.pdf
As easy as:
1) lift rear tires off the ground.
2) tighten the bolt on the brake drum all the way (until the brake drum cant be moved by hand.)
3) make a mark on the bolt and back it out 1.5 turns (the brake drum should move easy by hand)
DONE!
The parking brake should only need 3 clicks to be fully engaged. When I engage the parking brake now there is absolutely no movement in the truck when I let off the foot brake. I can clearly tell the difference from before and after and I wouldn't be surprised if the brake had never been adjusted since new.
All I had to do was tighten up the brake shoes. If you tighten the shoes and the parking brake still doesn't hold position then you may need to adjust the cable.
  #1646
Old 04-21-2014, 07:23 AM
ThisRoverGuy's Avatar
Looks good. What bumper is that? Looks to have good clearance. Which makes me wonder if you had to relocate your windshield reservoir.
Edit: NM on the reservoir question. I can see it peeking out. Wouldn't bother me enough to worry about relocating; especially because the Rover is white.
  #1647
Old 04-21-2014, 12:28 PM
ls1morethanyou's Avatar
i took it offroad this weekend, went hog hunting but came back empty. i need new tires and lift asap!
  #1648
Old 04-21-2014, 01:01 PM
mattmo78's Avatar
Got to do a little off road exploring this past weekend.
Attached Thumbnails What did you do with your DII today?-photo-2.jpg   What did you do with your DII today?-photo-3.jpg   What did you do with your DII today?-photo.jpg   What did you do with your DII today?-photo-4.jpg   What did you do with your DII today?-photo-1.jpg
  #1649
Old 04-21-2014, 02:42 PM
jamestfl's Avatar
installed TF shocks and steering damper. the old shocks looked original, and rode like it. gained about 1" of height, will need new springs, she's still a little low. much smoother, firmer ride and a lot less float in the steering.
  #1650
Old 04-21-2014, 09:29 PM
Dane!'s Avatar
Changed front axle seals and the 3rd member yesterday/today.
The diff that I changed was pretty bad, the pinion gear was cutting into the ring gear pretty bad, and the contact point was about a quarter inch on the outer part of the ring gear. If I had let it go it would have definitely sheared the ring gear.
Found my vibes were from my brand new front driveshaft, the joint on the diff end is binding, looks like it was pressed in incorrectly. I'm just going to buy a new joint and press it in myself, instead of returning it.
Quick Reply: What did you do with your DII today?
