Old Jul 15, 2014 | 07:44 AM
  #1981
driftology's Avatar
Originally Posted by Jared9220
Calling the truck reliable when you are only half way I'll Knock on wood for you. Good luck with the rest of the journey
made it! The only excitement we had was the a/c drains clogging up and soaking the floor. Ran 190 degrees at 17mpg over all with the a/c on full tilt most of the way. Oh and by the way the abs and traction control are pretty amazing. (don't have that stuff in my 88 rx7)
Old Jul 15, 2014 | 04:51 PM
  #1982
Jared9220's Avatar
Great news! Disco's get a bad rep with the whole "not reliable thing", but I think it's more the owners fault for that rather then the truck itself. Maintained properly they can be great trucks.
Old Jul 21, 2014 | 11:16 AM
  #1983
OffroadFrance's Avatar
Originally Posted by OffroadFrance
I fitted this professionally modified WABCO ABS shuttle switch kit today Landrover Discovery 2 Defender ABS Modulator Shuttle Valve Switch Repair Kit | eBay .
It works perfectly. There were no Amigos after a hard test drive. It's a similar fix to the Option B but doesn't need the earth.
Some tips on fitting insitu:
Attributes.
Allow 2-2.5 hours.
A lot of patience and an even temper.
Tools needed.
10mm ratchet swivel head combination spanner.
1/4" drive socket rathet.
1/4" drive 4mm Allen head socket.
Can of WD40 or similar.
Very small screwdriver or thin pick.
A LARGE SWEAR BOX
This task is not at all difficult just tedious and time consuming. Amazingly the most difficult part is raising and propping up the modulator which I did using a piece of 4x2 timber 4 inches long. The brake pipes can be flexed easily to accommodate this height of lift but don't forget to release them from the clips on the firewall. Removing the 3 screws is tedious as you can only turn them 1/8th turn even with a 1/4" ratchet. They remain stiff with resistance until totally removed as they have been inserted originally with a threadlock fluid. Putting the new scews back in is a doddle. In this mod it requires removing pins 8&9 from the original plug and inserting them in the new plug included in the kit. One wire in the kit goes into the old position of 8th pin and 9 isn't used anymore. It helps to remove the power steering reservoir and set aside and also the top of the air filter.
It is a fiddly job but relatively easy and very successful and also utilises the existing earth in the plug so no additional earth required. I can recommend this mod to overcome the 'trois amigos' issues provided the fault code is 'shuttle valve electrical failure' otherwise your problems may be elsewhere.
Update.
A couple of weeks on now and still no dreaded Amigos. This kit actually seems to work. I won't speak too soon but absolutely no sign of the 3 Amigos since fitting it.
Old Jul 22, 2014 | 08:49 AM
  #1984
ThisRoverGuy's Avatar
Hit 100,000 Miles over the weekend (2003 Disco). Got a picture of it
Old Jul 22, 2014 | 07:41 PM
  #1985
x1, you're dead right there Jared. Also many compare LR's to their ordinary family saloons that run them to work or the station every day and they are happy to put them in for a service but wince at the price to service a 4x4 which is far more complex. I have a pal who loves BMW's although his have had many issues and another pal who has BMW's hates them as they cost him a truckload of cash keeping them on the road.
"You can please some of the people all of the time and please all of the people some of the time BUT you can't please all of the people all of the time"
The perfect analogy for car owners. LR's are no different, they need to be looked after and often more so.
Old Jul 22, 2014 | 07:50 PM
  #1986
I'll have a go but to date I've been a lazy SOB and haven't yet bothered to learn posting attachments although I've read SuperSport's instructions.
I'm just in the process of upgrading the old truck with new suspension, shocks, steering gear, brakes and a host of other essential jobs. To me it's worth it with 123K on the odometer and good service from it from new. Under the hood is cleaner and tidier than the outside body and inside upholstery.
Old Jul 23, 2014 | 07:37 AM
  #1987
I was being lazy too. Didn't feel like downloading the photo, then finding and attaching it. But you've prompted me to spend the 30 seconds
Nothing no one here hasn't seen before, I'm sure. (Please forgive the ridiculously dusty instrument panel).
On reliability, I think this car's been pretty good to me. Bought it with 83k miles on it, and it's never failed to start or take me where I need to go. I have done a ton of work on it (mostly Disco Mike's 90k service list) and a PS pump replacement. My ownership started with Amigos, and the "Option B" fix took care of those. Then I had a SES light due to a bad O2 sensor. Replaced that and the light went off. Just a couple weaks ago, I got another SES light. Codes are P1319 and P1301 (cylinder misfire-low fuel). Just haven't had the energy to it (any advice folks?). When it was the O2 sensor, the truck was chugging fuel. Thankfully, this SES light doesn't seem to be affecting fuel mileage (maybe a little bit). So I'm not in too much of a hurry on it. However, my ownership has definitely been like a game of whack-a-mole. So, in short, they're "reliable," but with lots of work.
Attached Thumbnails What did you do with your DII today?-img_20140720_115420.jpg
Old Jul 23, 2014 | 09:44 AM
  #1988
Madlands's Avatar
Cleaned out the blower motor on my 04. It had huge chunks of foam in the basket. It fixed my vibration I was getting from it, but still only blows about half as hard as my 99. Thinking of swapping in a "new" (read:junkyard find) out of something else like I saw streetwolf do a while back.
Old Jul 24, 2014 | 04:49 PM
  #1989
dusty1's Avatar
Dropped bumper from stands onto my thumb while on creeper
Old Jul 24, 2014 | 05:05 PM
  #1990
Jared9220's Avatar
I installed a gasket on the leaky rear cover plate on my T-Case. I've been having a small leak from my T-Case for a while now and I ordered a gasket kit a few months ago and I finally strated replacing the gaskets I can get to without pulling the T-Case. I think I might have a few different leaks but it's not much (only about a nickel size spot on my garage floor each morning) but it's been driving me crazy since I bought the truck over 2 years ago. I tried blue devil stop leak but no dice so now I have to do it the right way.
I used zip ties to pull the parking brake cable out of the way so I could get my 1/2" drive up in there to break the 5 bolts (13mm) and stud (15mm) loose. Once I broke them loose the air ratchet made quick work of the rest of the job. I just pulled everything off and out to clean it up really good for the new gaskets.
There was some thick sludge on the inside of the back cover but it cleaned up nice.
What did you do with your DII today?-20140724_143936.jpgWhat did you do with your DII today?-20140724_143915.jpgWhat did you do with your DII today?-20140724_152707.jpg
New Gaskets going on. I used two of the bolts to keep it all aligned and installed it all in one piece.
What did you do with your DII today?-20140724_152759.jpgWhat did you do with your DII today?-20140724_152845.jpg
Use fresh thread locker on the bolts and stud when installing. Take extra time to get all the old thread locker off. I used a wire brush for the big stuff and through the bolts in the ultrasonic cleaner to finish it off.
What did you do with your DII today?-20140724_153906.jpgWhat did you do with your DII today?-20140724_155609.jpg
The rear cover is above the fill hole so I won't know if the leak is fixed until I take it for a drive and let it sit, but I'm letting the thread locker setup before I take off. The rear plate has a gap inside it where the bearing rides and oil gets trapped up in there when your driving. That pool of oil was leaking out over night onto my garage floor. If it continues to leak then I'll pull the cover back off and use RTV along with the gasket. I'll report back any problems
