Old Aug 18, 2014 | 01:55 PM
  #2101
overover02's Avatar
Scored a pair of 04' roof rails while at the U-Pull junk yard a couple weeks back. They are now prepped and ready for install (hope the spray on paint holds up). Figured, why not, since I have the headliner out...
Old Aug 18, 2014 | 03:52 PM
  #2102
OffroadFrance's Avatar
I fitted new galvanised front shock turrets as the previous LR items were delaminating with rust at the base bolt down ring. The new turrets are the skeletal type and very heavy duty, but, bad design as they foul the inner wing so had to do some 'cosmetic' inner panel reshaping. Fortunately I'd fitted new TF shocks allround and front springs recently so everything came apart easily thanks to copper grease. I test drove the new TF shockers and new springs - wow, what a difference they make to the handling. You never realise over the years how far your truck deteriorates. Next job is the new engine and gearbox mountings.
Old Aug 18, 2014 | 04:34 PM
  #2103
groeder24's Avatar
Went up to Bald Mountain trail this weekend and had a good time.
Would this be considered trail damage or tree clearance?
It scuffed the alpine window but luckily didn't break it.
Old Aug 18, 2014 | 06:16 PM
  #2104
MetalMarine's Avatar
changed out the steering rotary coupler today. new bosch 14v 150amp alt, last friday Friday for $325. local guy matched bputah's price.
Old Aug 18, 2014 | 11:43 PM
  #2105
G150driver's Avatar
Figured out my ABS fault. It was painfully obvious to have missed...
Old Aug 19, 2014 | 12:36 PM
  #2106
cmmoyer's Avatar
Originally Posted by OffroadFrance
You made the right move not to use it until sorted otherwise you could 'lunch' your engine. It may be an oil pump failure or an electronic failure - I'm guessing a bit ........... but it's better to not use it and have it diagnosed than risk seizing the engine or killing the crank + rods and possibly the pistons and bores.
Dropped the truck off again this morning for repairs. I had a misfiring cylinder and an air leak that I had no idea about. Turns out there a huge crack on the underside of the plastic duct that connects after the mass air sensor. So I had that replaced along with a new set of spark plugs and now it runs great!
Old Aug 19, 2014 | 07:35 PM
  #2107
GROVERDISCO's Avatar
Rebuilt front drive shaft ( thanks for all the posts on here, really makes it easy ) replaced right front hub with what I guess was a good used one, Amigos went off, yes!!! Anyone every bought one of the hubs selling off ebay for $120? I ordered one today to check it out and see what it's all about. Time to take the kids for icecream and then to the car wash to rinse her off.
1999 SE7 with ACE, 3" lift, ARB bumper with 11k# winch, 197000km
1999 SE 201000km engine over haul in progress
2003 SE 300000km RIP parts truck
2004 RR HSE 105000 miles.
Old Aug 20, 2014 | 04:54 AM
  #2108
99RedDisco's Avatar
. Suggest you start trying to do some of this stuff yourself, if you don't work on your own Disco you'll go broke paying someone else.
Old Aug 20, 2014 | 05:05 AM
  #2109
99RedDisco's Avatar
Default New Shoes
http://i1377.photobucket.com/albums/...psrjqm22n3.jpg
Swapped out 18's for 16's and put on a set of 265 75 16 Treadwright Wardens. Very happy with the look, Very happy with the Price, moderately happy with the overall ride.
Old Aug 20, 2014 | 02:21 PM
  #2110
Sir Axlerod's Avatar
Lost a water pump maybe?
