Old Oct 14, 2014 | 11:02 AM
  #2241
potxoli's Avatar
Originally Posted by DiscoRover007
Guys today I finally made some decent observations with my "tick" as you could call it. I hear a click or "tick" when I'm driving but I've noticed that I only hear it when accelerating and my foot is on the gas pedal. Otherwise when coasting it disappears. I won't hear this tick when I park the truck and rev the engine. It appears to only happen under load.
Does this mean anything?
Not sure if the ticking is from the engine based on your description. If it is, when I first got my truck, I heard a ticking only when underload. After a few tanks of premium gas and BG44 it seems to have gone away. Hope this helps.
Old Oct 14, 2014 | 01:59 PM
  #2242
DiscoRover007's Avatar
Wow so after putting a new radiator and waterpump my temps still climbed in the 200's. I see 194 more consistently now but when I've got the AC running I see it go up to 203-208. I've bled the system twice. I put two gallons of 50/50 in there but I think it can be topped off a little more. Otherwise it I think the Motorad 180 may have been the culprit this whole time. I'm not experiencing any leaks.
I just figured at 158,000 miles now it had to be the radiator or pump. Oh well at least I know I've got new parts in there now.
Old Oct 19, 2014 | 03:07 PM
  #2243
DustyLBottoms's Avatar
Default Gaskets
Replaced my timing chain, gears, and oil pump. A nice byproduct of this was taking care of the leaky oil plan gasket.
However, I'm now getting temps of 199F while driving with AC on, I used to be 194 on the dot.
Hopefully it's just an air bubble, I'll wait until it cools off and then bleed the system again.
Old Oct 19, 2014 | 04:40 PM
  #2244
potxoli's Avatar
Default New bumper
Car got some love this weekend. Thanks to Drowsap pointing out a good deal on this thread, I ordered a britpart bumper from Atlantic British for $400 on sale. Installed it this weekend. As with all work on the D2, it took close to one hour to unbolt the old bumper with all the rusted screws and bolts.
New bumper fit beautifully and is very well made. Had to do some minor trimming of the grill to fit it.
Also installed some LED interior bulbs. I can finally see inside the car!
Attached Thumbnails What did you do with your DII today?-2014-10-19-12.27.56.jpg   What did you do with your DII today?-2014-10-19-12.28.01.jpg   What did you do with your DII today?-2014-10-19-12.28.31.jpg   What did you do with your DII today?-2014-10-19-12.39.57.jpg
Old Oct 20, 2014 | 06:47 AM
  #2245
drowssap's Avatar
looks good, better than paying $700 for a stock bumper cover. by the picture it looks like you work off of A street in southie
Old Oct 20, 2014 | 08:08 AM
  #2246
potxoli's Avatar
Thanks! Now I need to figure out what I want to do about the washer bottle. The short term fix was a ghetto job with black duct-tape so it doesn't stand out as much.
pics where in chestnut hill.
Old Oct 20, 2014 | 08:23 AM
  #2247
drowssap's Avatar
if you don't have smog/air tubes you can move the washer bottle under the hood on the passenger side firewall you just have to shorten the long filler tube.
Old Oct 20, 2014 | 09:50 AM
  #2248
RicketyTick's Avatar
yeah, looks much better on your truck than in the ad where it looked bent. You should send them your pic to use..
Old Oct 20, 2014 | 04:28 PM
  #2249
OffroadFrance's Avatar
Bumper looks good better than I'd have thought for an aftermarket. You could also degrease the washer bottle and spray it with a spray can of black plastic paint. How to Paint on Plastic: 10 Steps (with Pictures) - wikiHow but ensure you degrease and rough the surface properly as plastic is often oil based and the surface is often still oily. I use cellulose thinners or brake cleaning fluid before spraying plastics.
Old Oct 20, 2014 | 04:38 PM
  #2250
potxoli's Avatar
yep, have plenty of space there. Will do that eventually.
