Old 10-03-2017 | 03:58 PM
Sixpack577's Avatar
You can give an old guy a heart attack taking pictures like that...lol.
Ha! No, I'll have 4 jackstands, 4 cinder blocks with boards on top, and whatever else I can throw in there.
I hate being under a jacked up vehicle.
  #4522
Old 10-04-2017 | 03:54 PM
Davis31052's Avatar
Default Help! Timing cover components reassembly
I’m in the process of installing my new oil pump gear set. I disassembled the oil pump pressure relief valve assembly for cleaning.
The shown parts below in picture one are the snap ring, cup with o-ring,spring and relief valve. Visible when the oil pump gears are removed. Got all that for sure.
Now, on the the other side of the timing cover, by the oil pressure switch, is another snap ring, cap with o-ring and spring. BUT no relief valve under the spring.
Am I missing something? Should there be oil pressure relief valve under both spring assemblies?
Attached Thumbnails What did you do with your DII today?-img_0267.jpg   What did you do with your DII today?-img_0266.jpg
  #4523
Old 10-05-2017 | 09:51 AM
JUKE179r's Avatar
Cleaning out the dust from inside of the instrument cluster and replacing lights with LEDs
I hope to never have all these lights come on all at once.
Disco 2 Instrument cluster held up to light the see all fault icons
  #4524
Old 10-05-2017 | 08:32 PM
Twix's Avatar
Looks good Juke! Did you peel the green backing off and relayer with blue?
  #4525
Old 10-05-2017 | 10:09 PM
JUKE179r's Avatar
Thanks!
No I didn't remove it. There wasn't a way to peel it off.
I wanted to remove the green screen from the odometer like I did on the clock. It's not that easy since I have to desolder 20 solder connections on the odometer. I didn't want to bugger it up so I left it alone.
  #4526
Old 10-06-2017 | 07:25 PM
Davis31052's Avatar
Got my Disco back together. No leaks and they truck runs much better. Now I need to do the front drive shaft. Anyone have a parts list for the u joints, and centering ball kit.
Thanks..
  #4527
Old 10-08-2017 | 06:13 PM
RUSTANDRUBBER's Avatar
4wd High
Default Pull a part score! 4 steel wheels for a steal!
70 bucks all 4! Almost didnt see them was about to leave. They were sitting across the asile. Just the very ones ive been saving up for!!. Got 16 of the lug nuts for them too. And Heated seat switches just in time for winter. One cup holder.
  #4528
Old 10-09-2017 | 07:49 PM
The Deputy's Avatar
Freed up the transfercase shifter cable, pin froze on TC end and was slightly bent. Took quite a bit of manipulation to get it straight again and moving freely. If l'd have removed the driveshaft...it probably would have gone better, but l can be stupid/stubborn/lazy about such things...lol.
But now it's like cutting butter...smooth.
Brian.
  #4529
Old 10-10-2017 | 07:34 AM
dgi 07's Avatar
Brian.
That isn't a fun job. Mine was seized on the transfer case end and snapped on the lever end. Had to drill it out and fabricate a pin. Now, I have anti-seize on the pin and spray PB blaster on it at every oil change.
  #4530
Old 10-10-2017 | 02:45 PM
The Deputy's Avatar
Yep, as I was lying under there...my mind kept saying..."go slow big dumby, cause if you break that clevest or cable...you're in for a small nigthmare". Yes, I'm going to start lubing it more often...sits an awful lot...being a trail-rig and all. Or...it just goes to show ya...it needs to get out trail riding more often.
Granted, the whole cable system seems under sized to me and why not give a person a longer clevest pin...one you can get vise grips on and spin to free up.
Brian.
Quick Reply: What did you do with your DII today?
