Old 10-17-2017, 08:40 PM
LR03NJ's Avatar
  #4542
Old 10-17-2017, 10:14 PM
Jwehking's Avatar
Is that paint or bare aluminum?
  #4543
Old 10-17-2017, 10:49 PM
Twix's Avatar
Replaced my blower motor. Still no air through the vents. Voltage at connector, cut the connector and hardwired. Have voltage, but no spin. I think the ground is gone, but I need a schematic to find out where it goes.
  #4544
Old 10-18-2017, 07:31 AM
LR03NJ's Avatar
No paint, all bate. I just clean them up.
  #4545
Old 10-18-2017, 02:58 PM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Good thinking. You should never, ever paint any aluminum engine block/heads/trans/transfer case/etc/etc. The beauty of aluminum is its heat transferring abilities. Paint neutralizes its ability to do so.
Man, you've been busy on that engine. Nice work. If she runs half as good as she looks...you should have a winner.
Brian.
  #4546
Old 10-19-2017, 01:40 AM
No Doubt's Avatar
Whoa! What a page for this thread. Fantastic roof rack and a head gasket that covers the liners so no more Tick.
Well done, gentlemen.
All that I did on my Disco 2 today was hand cut neoprene window/door gaskets to finally eliminate road noise from wind.
  #4547
Old 10-19-2017, 02:50 PM
LandBeard's Avatar
Originally Posted by MacRoadie
Replaced old, worn out roof rack with new BajaRack. Got front and rear lights mounted, as well as hi-lift and axe/shovel mount. Waiting for awning mount to arrive. Also, went with 1/2 floor this time, leaving front half of rack open for flexibility.
That Baja rack is dope! Eventually will get one and do a similar set up with aux lights across the front. Always need more light with how dim the older headlights are. Great job!
  #4548
Old 10-19-2017, 02:51 PM
LandBeard's Avatar
Inspiration while I have my manifold off! Looking good Gerry!
LR03NJ (10-19-2017)
  #4549
Old 10-19-2017, 05:22 PM
Jeff Blake's Avatar
Put in RTE 3" rear springs, d1 spring seats, and d1 spring retainers.
Holy moly the ride difference blows the terrafirma HD's out of the water (quick pavement test with lots of dips and bumps). And now I'm happily at 21" from wheel center to bottom of wheel arch all around.
I have the RTE front springs as well, uninstalled, but everything looks really good so I'll probably leave it for now... take it on a few offroading trips first to gauge the difference.
  #4550
Old 10-20-2017, 09:20 AM
JUKE179r's Avatar
I finally bought the parts to do my Big 5 cable upgrade.
I'm doing the negative cables first:
  • 0AWG from battery - to chassis
  • 0AWG from engine to chassis
  • 0AWG from alternator chassis to battery -
The positive cables I'll do a bit later:
  • 0AWG from alternator + to fuse link to battery +
  • 0AWG from battery + to starter +
Battery cable upgrade
Quick Reply: What did you do with your DII today?
